Author Topic: eBay: fifteen M122s (not F122s)  (Read 6570 times)
Offline ed_avis
« on: Sun, 09 April 2017, 09:54:40 »
https://www.ebay.com/itm/262227458872
$120 each is not super cheap, but I dare say they would take an offer for all fifteen...
« Last Edit: Sun, 09 April 2017, 13:20:09 by ed_avis »
Offline Techno Trousers
  • ʘ_ಠ
Re: eBay: fifteen F122s
« Reply #1 on: Sun, 09 April 2017, 10:15:00 »
By the part number, those are M-122s. Probably worth no more than $50 apiece, IMO.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #2 on: Sun, 09 April 2017, 11:08:02 »
Coincidentally I JUST released a video on how to tell them apart :D .
Offline taylorswiftttttt
« Reply #3 on: Sun, 09 April 2017, 12:50:58 »
removed
« Last Edit: Wed, 09 November 2022, 16:13:57 by taylorswiftttttt »
Offline ed_avis
Re: eBay: fifteen M122s (not F122s)
« Reply #4 on: Sun, 09 April 2017, 13:22:11 »
Oh!  I assumed that a square badge meant F... I guess this means I bought the wrong thing here, too: http://www.ebay.co.uk/itm/232285556094
Offline chyros
  • a.k.a. Thomas
« Reply #5 on: Sun, 09 April 2017, 13:48:04 »
Correct. None of the F122s had 139 model numbers as well, they all started with 611 or something IIRC. In any case, always ask for a pic of the back, it's easy to tell them apart then ;) .
« Reply #6 on: Sun, 09 April 2017, 15:32:12 »
All of my 122-key Fs have 611* model numbers, although my "Unsaver" actually has a sticker that calls it a Model M from 1996 - surely a re-stickered repair job.
Another give-away is that the Fs have 240-degree DIN plugs that are straight and have a threaded metal end that can screw into the female side. A plastic right-angle plug is sure to be an M, although it probably means a 1st-generation M.
But like Chyros said: metal back = F and plastic back = M.
- D Trump 2026-10-24
Offline OldIsNew
« Reply #7 on: Sun, 09 April 2017, 21:12:52 »
165273-0
My M122 with the jumbo legs and straight connector - I knew it was an M prior to buying so I'm happy with it - but like everyone is saying make sure to see the back if you're looking for an F.
165275-1
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #8 on: Mon, 10 April 2017, 07:42:55 »
Although the 90-degree connector does mean M, the threaded one also appeared on early Ms (1386887).
Also keep in mind the keyboards are compatible with each other so in a field repair IBM could have replaced the cable with a non-original one. The back is really the only reliable way to tell.
kishy.ca
Offline chyros
  • a.k.a. Thomas
« Reply #9 on: Mon, 10 April 2017, 12:17:22 »
Basically every past was changed bit by bit, so like I said, ONLY look for the metal backplate and don't look for anything else! ;)
Offline ander
  • I type, therefore I am
« Reply #10 on: Wed, 12 April 2017, 01:18:04 »
It is nice to see them all spiffed up like this, though.
Offline ander
« Reply #11 on: Wed, 12 April 2017, 01:23:25 »
My M122 with the jumbo legs and straight connector - I knew it was an M prior to buying so I'm happy with it...
And what's not to be happy about? These first-gen M-122s are just as fine as first-gen M-101s, like the 1390131 and 1390121. They just have a a bunch of extra keys, which is fun. (If you're into keyboards, why wouldn't you want more keys rather than fewer? I never did get the minimalization thing...)
And if anything, the 122s's extra weight and size makes them even more rock-solid than their 101-key counterparts, which is really saying something.. They're first-class M's (literally!) that set the standard for all buckling-spring boards that followed.
Offline chyros
  • a.k.a. Thomas
« Reply #12 on: Wed, 12 April 2017, 01:46:53 »
Ander's right. Typing on, or even just holding, any first-gen M, is just a really nice keyboard experience :) . They have something special about them.
« Reply #13 on: Wed, 12 April 2017, 21:47:52 »
There are still 15 available.
Have these gone out of fashion?
  • ʘ_ಠ
« Reply #14 on: Wed, 12 April 2017, 21:56:03 »
Too expensive for membrane buckling spring, IMO.
« Reply #15 on: Thu, 13 April 2017, 12:32:34 »
Yes, I think that it is unrealistic to ask more than $40-$50 for a terminal without a converter, even in pristine condition.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #16 on: Thu, 13 April 2017, 13:06:30 »
Unrealistic to ask it of enthusiasts, sure. But it's perfectly reasonable to ask it when your target market is businesses that are using obsolete technology in mission-critical proprietary applications and when the system is down it's a catastrophe. Granted, it's an unlikely component to fail to begin with.
kishy.ca
Offline ander
« Reply #17 on: Thu, 20 April 2017, 04:32:24 »
There are still 15 available... Have these gone out of fashion?
As you may know, unlike regular 101-key Model M's, which can be used with modern PC's (via PS/2, or with a $2 cable-style PS/2->USB converter—the cheapest and most compatible type, IMHO). 122-key terminal M's like these, though, require a Soarer's converter for RJ45 connectors, and they're $40 (assuming you're not prepared to convert the board internally yourself).
So for about the same dough they'd spend on one of these boards and a converter, most people would rather have 101-key M's, which take up less desk space and are easier to resell.
Besides, for $30–40, you can get a native-USB (or PS/2, if you prefer) genuine buckling-spring 122-key terminal-style Model M, in the form of one of the Unicomp-made OEM boards that turn up regularly on eBay.
So as kishy says (and kishy's a legend, BTW—hi kishy), the only people to whom it really makes sense to buy boards like these are people who are still using 20- to 30-year-old IBM terminal equipment and must replace an original M-122 that has pooped out. Each of those things (using systems that old, and M-122's pooping out) are highly unlikely, so it's even less likely they'd both happen.
I hope that explains it.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #18 on: Thu, 20 April 2017, 08:08:35 »
As much as I appreciate that, I'm just a guy with keyboards and a tendency to take them apart and ramble a bit :)
Hit the nail on the head with your whole reply.
kishy.ca
