Author Topic: Red PBT Esc Key - Dyesub or Double Shot  (Read 6135 times)
Offline S.J.
« on: Fri, 14 April 2017, 11:55:13 »
Hey guys,
I'm currently looking for a red PBT Escape key in either double shot or with dye-sub lettering... Oh and its for a Cherry MX stem!
I live in the Uk and i'm really struggling to find one! I don't mind shipping from abroad, so any suggestions would be welcome!  :-*
I know that WASD Keyboards sell them but they're currently out of stock!
Re: Red PBT Esc Key - Dyesub or Double Shot
« Reply #1 on: Fri, 14 April 2017, 12:04:54 »
Not going to find a PBT with double-shot.
What about this one?
https://elitekeyboards.com/products.php?sub=access,cherrymxkeys&pid=cds_redesc
Offline S.J.
« Reply #2 on: Fri, 14 April 2017, 12:08:56 »
Really?
I have PBT double-shot keycaps now... and as i said, WASD Keyboards sells them.
And I will have a look, thanks :)
« Reply #3 on: Fri, 14 April 2017, 12:14:38 »
Huh. Didn't know that. The only double-shot PBT I knew of was by Vortex.
Offline S.J.
« Reply #4 on: Fri, 14 April 2017, 12:21:19 »
Yep... here:
https://www.overclockers.co.uk/tai-hao-pbt-double-shot-keycaps-black-on-black-isoansi-layout-kb-011-ta.html
I know they aren't great quality as PBT goes... but hey ho!
And also, i'm looking for black legends :(
Offline Entropia
« Reply #5 on: Mon, 17 April 2017, 05:23:42 »
I've recently ordered an original Leopold red ESC key with front printed legend. They're also available with top print, but I don't know if it's dye sub (it doesn't matter with front legends). The keycap is 1,5 mm thick PBT.
http://www.ebay.com/itm/Leopold-Keycap-Esc-PBT-Red-front-side-printed-Cherry-MX-Mechanical-Keyboard/201754525276?_trksid=p2060778.c100290.m3507&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160727114228%26meid%3Dcc1d2364ba7c4084ae5d9f9a013583ee%26pid%3D100290%26rk%3D1%26rkt%3D1%26sd%3D201754525276
Offline thurst0n
  • Key-ping it real
« Reply #6 on: Wed, 19 April 2017, 00:04:07 »
What you're gonna wanna do is join Matt3o's drop on MD..
The base kit comes with TWO red escape keys!! Now that's value  :thumb:
« Last Edit: Wed, 19 April 2017, 00:07:25 by thurst0n »
-- Ducky One TKL --
Offline S.J.
« Reply #7 on: Wed, 19 April 2017, 07:06:35 »
Alright thanks guys... will look into it!
Offline DaBubbs
« Reply #8 on: Sat, 06 May 2017, 15:01:21 »
Mechanical Keyboards sells blank, and front and top print dyesub PBT red escape keys:
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=2176. They are out of stock at the moment but they typically refresh soon. I own two top print and they are black lettering and really nice quality.
When you are dead, you don't know that you are dead. It is difficult only for the others.
It is the same when you are stupid.
Offline DaBubbs
« Reply #9 on: Sat, 06 May 2017, 15:03:05 »
Oh, and note that the Leopold caps above are Cherry profile. Not sure if that is going to work for you or not.
