Author Topic: Tactile leg lubing on MX - do or don't?  (Read 1763 times)
Offline asgeirtj
« on: Sun, 16 April 2017, 08:16:20 »
Do you guys prefer lubing the tactile leg or not?
To my knowledge:
advantages of lubing it: more smoothness(I think the smoothness has an inverse relationship with tactility), more silent switch, disadvantages: less tactility
advantages of not lubing it: more tactility, disadvantages: louder, kind of a "rough" scrachy feeling, it feels like it needs lubrication imo.
is there maybe a best of both worlds: lubing it very lightly?
What is your preference?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline kmba
  • Formerly tameone
Re: Tactile leg lubing on MX - do or don't?
« Reply #1 on: Mon, 17 April 2017, 10:35:15 »
I prefer no lube on the legs (some, like zealios, come pre lubed there anyway), just on the sliders and face of the stem. This improves smoothness without sacrificing tactility.
keyboards.
Offline tkim
« Reply #2 on: Mon, 17 April 2017, 10:49:42 »
I prefer no lube on the tactile slider (zealios).
MX tactility is mild at best so I would tread with caution doing lubing which affects tactility
« Reply #3 on: Mon, 17 April 2017, 13:27:40 »
some do it, some don't
try both, it's a preference thing
