Author Topic: Blank metal keycaps?  (Read 5277 times)
Offline Entropia
« on: Sun, 16 April 2017, 10:46:10 »
When can I get single blank metal keycaps?
Offline Tom_Kazansky
  • Oblivion Knight
Re: Blank metal keycaps?
« Reply #1 on: Tue, 18 April 2017, 22:35:37 »
maybe 3D print it?
https://www.shapeways.com/product/DM4CBKHMF/blank-keycap-r3-1x1
NOTE: it's jus a suggestion, I have no experience with 3D print.
« Reply #2 on: Tue, 18 April 2017, 23:11:16 »
maybe 3D print it?
This is probably the best option other than searching for an ALU scarface cap.
You could also buy a RAMA cap but those aren't perfectly blank.
« Reply #3 on: Tue, 18 April 2017, 23:26:04 »
rama, or some of the hammer caps
or if you want to go hard, look for a scarface set
