Author Topic: [WTS] Nothing!  (Read 11133 times)
Offline emdude
  • Trade Count: (0)
[WTS] Nothing!
« on: Mon, 17 April 2017, 21:27:46 »
Hi everyone, trying to unload stuff I don't need or care for anymore.
All prices include shipping and PayPal fees.  CONUS only, please.
[WTS]
Nothing.
[WTB]
Nothing.
Thanks for looking!
Sold
IBM Model M SSK 1391472 -- $175
Timestamp Album: http://imgur.com/a/xsLPh
Completely cleaned and tested to work.  In good cosmetic condition, missing a few rivets (see album) but feels fine.  Original Ctrl (1), Alt (1), Esc, and Tab keys were replaced with two-piece ones by the previous owner.  SDL cable included.
NMB PC122 Keyboard -- $40
Album + Timestamp: http://imgur.com/a/t3iWI
PS/2.  I got this from a recycler and I just don't have the time nor the interest to clean this up.  Tested to work completely.  The switches are in decent condition but the board is pretty grimy.   It uses clicky black Space Invaders + light blue clicky spacebar switch.
IBM 5140 60% Custom Keyboard w/ SKCM Brown Alps -- $180
Album + Timestamp: http://imgur.com/a/AMuGg
A custom 60% keyboard with Hasu's Alps64 PCB and a plate that I designed to accommodate the IBM 5140 layout.  It's a very nice keyboard, I'm just not fond of the 60% form factor.  It uses Alps SKCM Browns and the full IBM 5140 PBT keyset.
It also comes with:
  • Leftover function/misc. keys from the keyset that was used with the 60% keyboard.
  • Extra complete 5140 keyset from which the 2nd Ctrl key was sourced.  The [ { and ' " keys are scratched.
  • 20 SKCL Compact Green switches from the keyboard the Brown Alps were sourced.
100ish Orange Alps switches -- $55
Timestamp: http://i.imgur.com/qTWYhvL.jpg
From an Apple Extended Keyboard and all working before desoldering.  They are in good condition, but a bit dirty so I recommend you clean these before throwing them in something.  Also includes a cream locking switch.
Apple Extended Keyboard Keyset -- $25
Timestamp: http://i.imgur.com/DzkkwjH.jpg
Comparison: http://i.imgur.com/HL8IvIz.jpg
Complete.  This keyset was originally missing the Home key.  It has been replaced but the font weighting is a little thinner than the rest of the keys.  Above pic compares it to surrounding keys.
Keys have been cleaned and includes all stabilizers + inserts.
Old timestamp/photo album: http://imgur.com/a/CT4cv
80 Orange Alps switches -- $45
These switches were cleaned with an ultrasonic cleaner.  They feel great.
Apple M0116 keyset -- $15
Alps mount. PBT Dyesubbed. Complete. Does not include stabilizers.
NIB NMB/Hi-Tek RT101+ (RT101-LC) -- $60
Tactile Grey Space Invaders switches. I used it for a few keystrokes, then decided I did not like it at all.  Other than that, it is unused.
Unicomp RGB Modifiers + Red Esc -- $12
Timestamp: http://i.imgur.com/ZAczayd.jpg
Focus FK-5001 -- $50
Pine White Alps.  Switches were cleaned and feel fine.  The calculator works when plugged into a PC but I did not replace the battery cell.  The keyboard works when plugged into a PC with a native(?) PS/2 port, but it does not work with an active PS/2-USB adapter.  It may need a Soarer's Converter.
IBM Model F122 -- $100
Timestamp/Photos: http://imgur.com/a/ELxYU
Capacitive Buckling Spring. P/N 1390832. It was apparently refurbished by IBM in 2001(!).
I suspect it is a 611034* series F122, but it was given the P/N of an M122 for some reason.  Has all the typical issues of an F122, rusty plate, very slight crack in the top-left of the case.  Two of three screw mounts on the case began to crack and break upon disassembly so I applied epoxy to fix them.  I shored up the third screw mount with epoxy as well just in case.
See the pics for details.
SGI Granite keyset -- $55
Alps mount. PBT Dyesubbed. Missing the ./Delete numpad key, but you're probably getting this for a custom 60%/TKL. :P
Includes enough stabilizers for a 60%/TKL.
IBM Model M SSK 1392980 -- $185
Timestamp/Photos: http://imgur.com/a/Zakws
I got this refurbished.  It is in fantastic physical condition, and appears to have seen little, if any, use since it was refurbished.  There is some shine on the keys, but the barrel plate is nearly dust-free.  Note that this is a terminal Model M, so it will require a controller swap or Soarer's Converter.
« Last Edit: Fri, 22 September 2017, 02:34:43 by emdude »
Current drivers: IBM Model M SSK
Offline smithyithy
  • Trade Count: (0)
  • a l p s
Re: [WTS] Random Alps Stuff, Terminal SSK, NIB RT101-LC
« Reply #1 on: Tue, 18 April 2017, 10:25:56 »
I'd be interested in the SGI caps if you change your mind.
KBD75; Alps64 trio; some other stuff
Offline emdude
  • Trade Count: (0)
« Reply #2 on: Tue, 18 April 2017, 23:56:08 »
Bump!
@smithyithy, thanks!  If they are still available after some time has passed I will let you know!
Offline emdude
  • Trade Count: (0)
« Reply #3 on: Thu, 20 April 2017, 16:07:15 »
Bump!  Added Unicomp keysets.
Offline emdude
  • Trade Count: (0)
« Reply #4 on: Fri, 21 April 2017, 22:13:32 »
Bump!
Offline emdude
  • Trade Count: (0)
Re: [WTS] Random Alps Stuff, Terminal SSK, NIB RT101-LC, Unicomp Keysets
« Reply #5 on: Sat, 22 April 2017, 22:18:09 »
Bump!  Slight price cuts to some items.
Offline emdude
  • Trade Count: (0)
« Reply #6 on: Sun, 23 April 2017, 22:19:19 »
Bump!
Offline emdude
  • Trade Count: (0)
Bump!
Offline emdude
  • Trade Count: (0)
Bump!
Offline emdude
  • Trade Count: (0)
Bump! Slight price drops on some other things!
Offline emdude
  • Trade Count: (0)
Re: [WTS] SGI Keyset, Focus FK-5001, Terminal SSK, Unicomp Keysets
« Reply #10 on: Sat, 29 April 2017, 15:30:33 »
Bump!
Offline emdude
  • Trade Count: (0)
Re: [WTS] SGI Granite Keyset, Focus FK-5001, Terminal SSK, Unicomp Keysets
« Reply #11 on: Sun, 30 April 2017, 20:33:03 »
Bump!
Offline emdude
  • Trade Count: (0)
Bump!
Offline emdude
  • Trade Count: (0)
Bump! SSK price drop!
Offline emdude
  • Trade Count: (0)
Bump!  Paypal fees are now included with the price as well; it was pretty arbitrary to exclude them anyway.
Offline emdude
  • Trade Count: (0)
Bump!
Offline emdude
  • Trade Count: (0)
Bump!  Looking for Model M Ctrl keycaps!
Offline emdude
  • Trade Count: (0)
Offline Petch
  • Trade Count: (0)
If you open up to international, I'd be interested in the SSK :) And obviously willing to pay a bit more for the shipping
« Last Edit: Sat, 13 May 2017, 10:59:49 by Petch »
Offline JP
  • Trade Count: (0)
PM'd on F122.
About Me | The Collection
Offline emdude
  • Trade Count: (0)
Bump!
@petch, thanks for the offer, I will keep it under consideration.
Offline emdude
  • Trade Count: (0)
Bump!  Price drop on SGI Granite set.
Offline emdude
  • Trade Count: (0)
Bump!
Offline emdude
  • Trade Count: (0)
Re: [WTS] NMB PC122, AEK Keysets, Orange Alps // [WTB] IBM 42H1292 Cable
« Reply #23 on: Mon, 07 August 2017, 23:16:09 »
Bump!  New stuff added. Am also looking for an IBM 42H1292 or equivalent cable. :)
« Last Edit: Mon, 07 August 2017, 23:18:32 by emdude »
  • Trade Count: (1)
« Reply #24 on: Tue, 08 August 2017, 06:48:17 »
Those 122-key NMB Hi-Teks are pretty nice, if you like clicky switches.
- D Trump 2026-10-24
Offline emdude
  • Trade Count: (0)
Re: [WTS] Brown Alps 60%, NMB PC122, Apple Keysets // [WTB] IBM 42H1292 Cable
« Reply #25 on: Sat, 12 August 2017, 13:27:32 »
Bump! Price drops on current items and I've added a 60% keyboard w/ Brown Alps that I've been meaning to let go of for some time!
Offline emdude
  • Trade Count: (0)
« Reply #26 on: Wed, 16 August 2017, 01:37:10 »
Bump!
Offline ReadmeDotTxt
  • Trade Count: (0)
« Reply #27 on: Wed, 16 August 2017, 04:52:59 »
pmd
Offline nachie
  • Trade Count: (0)
    • KapCave
« Reply #28 on: Wed, 16 August 2017, 13:10:27 »
Pming
AHKB | GSKT-00 | Arya | Båge | Paladin64
  • Trade Count: (0)
« Reply #29 on: Wed, 16 August 2017, 13:12:59 »
Oh, man. That Brown Alps is one of the best 60% Alps I've seen.
Offline emdude
  • Trade Count: (0)
« Reply #30 on: Wed, 16 August 2017, 15:42:50 »
Thanks!  The keyboard will be heading to a new home now, just sold!
Offline JP
  • Trade Count: (0)
Re: [WTS] NMB PC122, Apple Keysets // [WTB] IBM 42H1292 Cable
« Reply #31 on: Thu, 17 August 2017, 06:32:10 »
That's a special board for sure. Nice work on that.
Offline emdude
  • Trade Count: (0)
« Reply #32 on: Tue, 29 August 2017, 12:28:12 »
Bump!
Offline emdude
  • Trade Count: (0)
Re: [WTS] IBM Model M 1391472, AEK Keyset // [WTB] IBM 42H1292 Cable
« Reply #33 on: Fri, 08 September 2017, 11:39:33 »
SSK Bump!
Offline emdude
  • Trade Count: (0)
« Reply #34 on: Sat, 16 September 2017, 13:56:24 »
Bump!
  • Trade Count: (1)
« Reply #35 on: Sat, 16 September 2017, 19:35:30 »
A clean complete SSK for $175 shipped and you aren't getting any takers? That is surprising.
Offline RealDealSexAppeal
  • Trade Count: (0)
Re: [WTS] Nothing!
« Reply #36 on: Tue, 26 September 2017, 12:04:21 »
DM'd you about the SSK
