Author Topic: Custom switches help  (Read 1691 times)
Offline Encabulator
« on: Tue, 18 April 2017, 09:32:16 »
I'm looking to replace a couple of switches I use on my keyboard I use for rhythm games (Z,X,D,F,J,K). I want a shorter actuation distance but with a slightly heavier switch. So currently, Im thinking something along the lines of a gateron black in terms of weight and smoothness with the actuation point of a cherry mx silver. Where should I start?
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Offline Applet
Re: Custom switches help
« Reply #1 on: Tue, 18 April 2017, 10:27:33 »
Get the silver and switch the spring with a gateron black and lube the silver (if needed)? You won't get that shorter actuation anywhere else
