Author Topic: The Velocifire TKL-01 $29.99 Brown Switch backlit Keyboard...Does it suck?  (Read 10170 times)
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Offline yotravel
Hi,
Thank you for your review.  I am purchasing the new version, the TKL-02, based on glowing recommendation and the positive reviews at Amazon for both this and the TKL-01.  It will be my first mechanical keyboard. I thought I would let you know that the TKL-02 uses Outemu brown switches, which you seem to say should be even better!
Cheers!
