Author Topic: Do Zorro Switches Break In?  (Read 2899 times)
Offline Encabulator
« on: Tue, 25 April 2017, 19:15:08 »
I've been hearing quite a bit about the velocifire keyboards (30 USD for TKL, standard layout,  doubleshot abs keycaps, single color backlighting) but the main thing that is kinda turning me away is the switches, zorro brown. I've heard from reviews that theyre pretty grainy and have a weak tactile bump. Is there anyone here that have used zorro switches for a longer period of time? If so, how are they working out in the long run, change in key feel at all? Thanks!
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Offline klennkellon
  • I like bottoming out
Re: Do Zorro Switches Break In?
« Reply #1 on: Tue, 25 April 2017, 23:21:32 »
if theyre grainy and have a weak tactile bump that means they feel exactly like mx browns.
yes they do break in after awhile so they will smooth out somewhat.
