Author Topic: Shift key doesnt work GH60 rev c  (Read 2215 times)
Offline SnarlesBarkley
« on: Tue, 25 April 2017, 23:56:58 »
I just finished my first build on a GH60 rev c and the right shift key doesn't work. I used Easykeymap and flip flash for the firmware. I've updated the software and set the switch to any letter or number and nothing happens. I desoldered and swapped out the switch thinking that was the problem but the issue was still there.
Noob Soldering job:
http://imgur.com/9XfMatI
Is my soldering job the reason the shift key doesn't work? or the firmware?
Offline Tactile
Re: Shift key doesnt work GH60 rev c
« Reply #1 on: Wed, 26 April 2017, 00:07:31 »
My money is on a firmware problem. My Rev C has a split right shift and to make it work right (with the shift on the inside and the FN key on the outside) I had to swap K3C & K3D in QMK. I don't know anything about the programming tool you're using but I'll bet the problem is something similar. In fact I'll bet your non-functioning "right shift" key is really a FN key, if you can think of a way to test it.
REΛLFORCE
« Reply #2 on: Wed, 26 April 2017, 00:23:45 »
sorry the programming tool im using is easy AVR
« Reply #3 on: Wed, 26 April 2017, 00:25:05 »
OMG its fixed tyvm
