Author Topic: SIIG Minitouch with Monterey switches, new, $99  (Read 4400 times)
Offline ed_avis
« on: Fri, 28 April 2017, 03:07:28 »
http://www.ebay.com/itm/182520963844
The seller also has a shrinkwrapped new one for a higher price.
Be warned that 'blue cube' and similar USB converters don't necessarily work with this board.  It works plugged into a PS/2 keyboard socket with a simple adaptor, and I expect that a Soarer's converter would handle it.
Offline orihalcon
Re: SIIG Minitouch with Monterey switches, new, $99
« Reply #1 on: Fri, 28 April 2017, 07:12:52 »
I can confirm that Soarer's Converter does work with these.
Offline Touch_It
« Reply #2 on: Mon, 01 May 2017, 13:08:46 »
Monterey switches are pretty awesome.  I imagine brand new ones feel quite nice.  Mine are pretty worn.
Offline ander
  • I type, therefore I am
« Reply #3 on: Tue, 02 May 2017, 02:07:28 »
Sold.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #4 on: Tue, 02 May 2017, 06:53:41 »
Are you sure these do in fact have authentic "Monterey Switches" or another simplified Alps copy, using sub standard bits/parts?
Remember there are a lot of differing Alps type switches and many companies that had built them, just would like to know if these are in fact the real deal.
Offline ed_avis
« Reply #5 on: Tue, 02 May 2017, 14:06:53 »
If you want to see the difference between new and worn switches, compare a commonly-used key like E with a less frequent one like Insert.
