Author Topic: DIY Numbpad Kit  (Read 3136 times)
Offline Demo
DIY Numbpad Kit
« on: Sat, 29 April 2017, 05:12:39 »
At some point (when I can find a kit) I'm gonna build a 96key board. I figure in the mean time I can get a numbpad kit to practice and to have a numbpad in the mean time. I see 3 kits, Satan Pad off Alieexpress which looks good but doesn't seem to be programmable, The Felix from unikeyboard which is programmable but kinda ugly and pricy. Also got a bluetooth one up ob mass drop but it doesn't seem programmable and is pricy. Any other options around? Should I just go for a premade one and if I really wanna mess with it I could de solder and re solder switches to it?
Offline TalkingTree
    • My projects
Re: DIY Numbpad Kit
« Reply #1 on: Sat, 29 April 2017, 05:20:03 »
Consider MOZ' SAMpad, kicad source files are provided so you can add or remove whatever you wish.
Offline Demo
Re: DIY Numbpad Kit
« Reply #2 on: Sat, 29 April 2017, 07:02:03 »
Doesn't look like that's a ready product
Offline TalkingTree
    • My projects
Re: DIY Numbpad Kit
« Reply #3 on: Sat, 29 April 2017, 07:30:51 »
Right, then your options are those you listed, unless you can find anything useful here.
