Author Topic: hhkb question  (Read 3324 times)
Offline alexofthewest
hhkb question
« on: Sun, 30 April 2017, 18:41:40 »
Offline nmur
  • ಠ_ಠ
Re: hhkb question
« Reply #1 on: Sun, 30 April 2017, 18:43:46 »
ye
that link has amazon links in it
Offline kiwi99
  • that's a gnarly dookie
Re: hhkb question
« Reply #2 on: Sun, 30 April 2017, 18:44:12 »
Yes they're available on the Japanese amazon site.
Offline iLLucionist
  • Topre is Love.
Re: hhkb question
« Reply #3 on: Sun, 30 April 2017, 18:52:39 »
Yup Amazon. Haven't seen them on Europe amazon though...
Re: hhkb question
« Reply #4 on: Sun, 30 April 2017, 19:05:21 »
that website literally has the amazon links on it
Offline clickityClackity
Re: hhkb question
« Reply #5 on: Sun, 30 April 2017, 20:34:34 »
Fyi, at least in the US you can order from the Amazon JP. Can't use your US login for some reason though.
Also, for this price you can get an HHKB and TMK controller from Hasu and have BT plus complete customizability.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Offline scudley
  • nobody howls at the sun because it sucks
Re: hhkb question
« Reply #6 on: Mon, 01 May 2017, 11:45:45 »
FYI 1upkeyboards got Hasu BT controllers back in stock on Friday of last week. $85 for that, $15 LiPo battery and a used HHKB you'd end up saving some money if you want to go that route
HHKB Type-S | GH60 Satan - 67g Cherristotles | GHpad - 78g Zealios
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
Re: hhkb question
« Reply #7 on: Mon, 01 May 2017, 11:54:31 »
Battery life and build quality are a bit better if you buy the official Bluetooth. If you want the customization and don't mind a lil DiY the hasu is not bad.
Personally would prefer the official though.
Re: hhkb question
« Reply #8 on: Mon, 01 May 2017, 12:28:09 »
What's battery life on the official version? Mine is great, I recharge about once a week with heavy daily use.
Just wondering, I couldn't love without the full customization.
Sent from my Lenovo PB2-670N using Tapatalk
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
Re: hhkb question
« Reply #9 on: Mon, 01 May 2017, 13:15:28 »
Month and a half to two months usually.
Re: hhkb question
« Reply #10 on: Mon, 01 May 2017, 13:21:58 »
That's really good. Personally the battery life on mine is perfectly fine. Giving up customizations for that would definitely not be worth it.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
Re: hhkb question
« Reply #11 on: Mon, 01 May 2017, 13:27:14 »
When I had one with a hasu BT the battery was fine for me as well, but I just used the stock hhkb layout so no need for customization lol.
Re: hhkb question
« Reply #12 on: Mon, 01 May 2017, 18:32:35 »
thanks for all the replies, well I no longer have all my soldering tools and that really isnt an option at all at the moment, is there a place that sells the hasu hhkb? What would it cost used vs buying the official bluetooth hhkb? A lot of people on here are strongly for the hasu controller one, what are the pros and cons to each. I definitly heard battery life in favor of the official.
« Last Edit: Mon, 01 May 2017, 18:34:16 by alexofthewest »
Offline scudley
Re: hhkb question
« Reply #13 on: Mon, 01 May 2017, 18:51:32 »
No soldering required to install the Hasu controller, just have to open up the case. Only tool you need is a small screwdriver
Offline _rubik
Re: hhkb question
« Reply #14 on: Tue, 02 May 2017, 14:17:09 »
I'm pretty sure everyone has said it already: Amazon has a few listed. Not sure what quantities these sellers have though.
