Author Topic: DIY Costar style stabilizers  (Read 3954 times)
Offline steinerlein
« on: Tue, 02 May 2017, 04:08:26 »
Hey all,
I am fairly new on this forum and I hope I didn't miss an existing thread on this topic.
Fisrt off: I am basend in germany, so just buying parts is very difficult for me.
I plan on building a one off plate-mount and handwired keyboard but I am missing the stabilizers. I have some cherry MX keyboards laying around, but the stabilizers in there are all pcb mounted so I can't use these. I do have access to a lot of tools like a CNC mill, though.
I would like to attempt to make Costar style plate mount stabilizers. What I have decided so far:
  • All plastic parts will be made from flat stock
  • thus, I will adapt the design features of all plastic parts to be a 2D contour.
  • I will bend the wires by hand
I will start building my own stabilizers in CAD but I am most grateful for any input on dimensions. If you have Costar stabilizers, calipers and a bit of time I would be very thankful for your help in getting some of the dimesions right.
Or are there maybe resources I didn't find that already hold everything I need?
In any case I will update this thread as progress is being made!
Offline steinerlein
Re: DIY Costar style stabilizers
« Reply #1 on: Tue, 02 May 2017, 11:05:27 »
My progress from today:
167493-0167495-1167497-2167499-3167501-4
And if anyone using fusion would like have a look, you can do so here: http://a360.co/2qoUWuh
I am thankful for any input, especially if someone could compare some of the measurements with a costar stabilizer.
Cheers!
Offline TalkingTree
    • My projects
« Reply #2 on: Tue, 02 May 2017, 14:35:25 »
That's very nice. I'm just unsure about the stability of the T shaped insert over a cross shaped one.
I have no input to give you but BunnyLake has had Costar inserts made by JTK. You could ask him some info, he's a friendly fellow.
Offline steinerlein
« Reply #3 on: Tue, 02 May 2017, 15:24:37 »
Yeah, I did think quite thoroughly about that, too. As I see it, even just a flat piece should be strong enough. It might even be that the T-shape only came about to accurately position the keycap on the stem. Not sure about that, though.
We will see if it works as soon as I have made a test  :thumb: I am just waiting for some super fine end mills.
