Author Topic: TKL ISO PCB  (Read 3911 times)
Offline phinix
TKL ISO PCB
« on: Tue, 02 May 2017, 16:23:03 »
Can you buy Filco TKL pcb?
I would like to get TKL pcb and mount Zealios on it, but I don't think I could deal with un-soldering switches.
I hope I can handle soldering the to pcb...
Or can I buy any TKL ISO pcb that would fit filco case?
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
Re: TKL ISO PCB
« Reply #1 on: Tue, 02 May 2017, 16:28:29 »
Possibly a phantom? I know they fit filco cases, but do require a good bit more soldering.
Re: TKL ISO PCB
« Reply #2 on: Tue, 02 May 2017, 20:33:15 »
Phantom, and I think b.87 can do it.
Offline phinix
Re: TKL ISO PCB
« Reply #3 on: Wed, 03 May 2017, 02:37:12 »
I'm guessing they don't do ISO?
Also, they don't come with presoldered bits, so only switches would need to be soldered?
Offline Targa-TV
Re: TKL ISO PCB
« Reply #4 on: Wed, 03 May 2017, 02:43:20 »
The Phantom does support ISO.
https://deskthority.net/wiki/Phantom
Filco MJ2 Black - MX Red | VA88M - MX Brown | Cherry G80-3000 -
  MX Blue | Cherry G80-3000 - MX Black | XD75re - MX Silent Red
[image]http://i.imgur.com/our8YUc.png[/image]
Offline rasmusx
Re: TKL ISO PCB
« Reply #5 on: Wed, 03 May 2017, 04:39:05 »
Anybody knows where to get Phantom PCB or kit?
Offline TalkingTree
    • My projects
Re: TKL ISO PCB
« Reply #6 on: Wed, 03 May 2017, 04:44:56 »
The PCB can be bought on MechanicalKeyboards.com, while the closest shop to your for the Teensy is Falbatech.pl. Diodes and resistors are easily found on eBay or at your electronics supplier.
Offline phinix
Re: TKL ISO PCB
« Reply #7 on: Wed, 03 May 2017, 08:49:36 »
« Last Edit: Wed, 03 May 2017, 10:03:52 by phinix »
