Author Topic: [IC] GH60 PCB with split long keys and arrows, full LED, buttom LED  (Read 6105 times)
Offline sennin32
    • Doyu Studio
Hi, guys, we're Doyu Studio and I'm sennin32.
Some geeks might know that we stop offer Satan PCB months ago.
Mainly because the packing quality.
We spend too many time to fix before they can ship.
Even we change supplier, the quality is horrible.
So, we plan for making a replacement PCB recently.
Instead of basic GH60 PCB, we tried to add some new ****.
For me, keyboards without arrow is not a good option for daily use.
I were a soft engineer before, without arrow is okay, but arrow is important for me now.
If we want to add arrow, there's some thing we have to change - Right shift.
So we're thinking about split space bar into 2 key.
There's some requirement of this design:
1. Contain arrows
2. Keep Shift on the right hand
3. Don't change alpha layout
4. Keycap must easy to get
5. Micor USB, cable is much easier to find
6. Support as many as possible of existing GH60 parts
The layout support :
http://www.keyboard-layout-editor.com/#/gists/a1bef8bf2784f5d009c96665a19bfc5e
This idea is mainly come from minila, so, the space bar has the same size as minila.
This is the PCB design now.
One disadvantage is one of the screw won't able to use because of add keys.
(The screw near spacebar)
PCB design is almost finished, we're now checking if there's any bug and making optimization.
The 3u space's stabilizer mounting hole is not yet finished.
We haven't confirm correct dimension with factory.
First question is will you guys interesting in this layout?
Or do you have any idea for the layout?
Because of the new layout.
We have to make a new firmware before we start massive manufacturing.
Means we'll have some sample PCB for design new firmware file and testing.
Since making 1 PCB and making 10 PCB has almost the same cost.
(Actually, cost for SMD soldering for 1 Pcs is 1/2 of making 1k Pcs..., I mean, total cost)
We might make around 10 samples.
Give away around 5~8 Pcs for reviewing and testing purpose.
But have no idea how to chose guys we should send now.
Second question is could you give us some idea of how to chose who we should give sample to?
This PCB might spend around extra 2 months before manufacturing.
So this GB won't start soon O_Q.
The other small issues:
Will you interesting in costar stabilizer and costar plate?
(They won't be universal, only support several layout, so price will higher since we have to making different plate support different layout)
Interesting in PCB GB with keycaps?
« Last Edit: Fri, 05 May 2017, 04:03:21 by sennin32 »
Offline anonymous
Re: [IC] GH60 PCB with split long keys and arrows, full LED, buttom LED
« Reply #1 on: Sat, 06 May 2017, 05:52:19 »
Nice layouts you got there. Here is my suggested layout :)
It hard to find a keyset with split spacebar. My layout is closest to standard so its easier to find keycaps. There is a shift on the right but the question mark will be on the bottom row
Offline N0GLUT0N
« Reply #2 on: Sat, 06 May 2017, 06:25:14 »
My dream layout, if you could support that I would buy multiple!
(The split left shift is different and the backspace is 2u, I am fine with the spaces not being the same size but its prefered.
Offline kawasaki161
« Reply #3 on: Sun, 07 May 2017, 05:36:33 »
I'd love to see these bottom rows:
Offline Eturior
« Reply #4 on: Sun, 07 May 2017, 13:18:01 »
You should check out the Banana Split project that is going on currently and coming to group buy soon! https://geekhack.org/index.php?topic=84891.0 It covers that layout :)
Offline sennin32
    • Doyu Studio
« Reply #5 on: Sun, 07 May 2017, 13:37:40 »
But the pic you post has no split spacebar 0.0...
The shift is possible cause it can flash your own layout.
No need to be question mark, I think question mark with 1.75u is harder to find than 3u spacebar  :D
Offline sennin32
    • Doyu Studio
« Reply #6 on: Sun, 07 May 2017, 13:42:32 »
Looks pretty good.
And I just check it again.
Seems it is possible.
But if you prefer take few keys away.
Custom plate should be necessary.
Offline sennin32
    • Doyu Studio
« Reply #7 on: Sun, 07 May 2017, 13:51:14 »
I guess this will be close.
If put space bar to center.
That will too far from universal.
We have to make 1000 pcs to reduce the cost in single batch.
Not really possible to make some not universal PCBs.
Haha, I just checked, yup you should take a look at that  :))
What you post is exactly the same thing as the other thread.
Offline kawasaki161
« Reply #8 on: Sun, 07 May 2017, 14:07:42 »
Oh, yeah, I know that that one will support it, but I'd love to see even more PCBs supporting that :)
