Author Topic: someone has a can of black spray paint  (Read 4738 times)
Offline trievalot
« Last Edit: Sun, 21 February 2010, 05:13:03 by trievalot »
[SIGPIC]
Offline ch_123
« Reply #1 on: Sun, 21 February 2010, 05:57:09 »
They're Keytronics, considered to be the best rubber domes, but rubber domes nonetheless.
Offline kode
« Reply #2 on: Sun, 21 February 2010, 07:06:26 »
Looks a lot like a KT1000, yes.
Offline TexasFlood
« Reply #3 on: Sun, 21 February 2010, 14:43:08 »
Maybe I should paint this one black and call it a DAS?
I know, the DAS isn't a designer, but the designer isn't bad for a membrane.
Used GIMP to see what the keytronics designer might look like if I did whip out a can of black spray paint on it:
As opposed to the image in the posted link:
It's tempting to get the paint out...
« Last Edit: Mon, 22 February 2010, 01:15:14 by TexasFlood »
Offline spolia optima
« Reply #4 on: Mon, 22 February 2010, 11:33:38 »
I was always curious about the "weighted" keys on the original DAS. What the fuc*?
How much did they weight, and what did this bring the actuation force down to?
keyboards!
Offline salcan
« Reply #5 on: Mon, 22 February 2010, 12:25:04 »
Keytronic Lifetime designer is probably my favorite (non ergo) rubber membrane board. It's a solid keyboard that is relatively cheap, with a good warranty.
Here is the chart from the original DAS, AFAIK it's what keytronic meant by weighted keys...
Offline TexasFlood
« Reply #6 on: Mon, 22 February 2010, 13:49:55 »
Looks basically identical what keytronics shows for lifetime designer "ergo technology":
I've had mine a while, not sure if it has this.  The Keytronics Lifetime Designer web page states "Now shipping with Ergo Technology", so does that imply that the older models did not?  Not sure, but either way it's one of the nicest rubber membrane keyboards I've used just as salcan stated
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #7 on: Mon, 22 February 2010, 14:05:30 »
I think it's one of these at heart...at least the case is.
kishy.ca
Offline salcan
« Reply #8 on: Mon, 22 February 2010, 16:43:09 »
Quote from: TexasFlood;159989
yeah, Das just copied the art, nice job.
I think they LT Designer always had the "ergo technology", it just sounds better than "weighted keys" which is totally confusing. They keys are all the the same, some just require more force to press down.
Need to dig out my Designer and take it for a spin! It's my only keyboard that's in storage.
« Last Edit: Mon, 22 February 2010, 16:44:29 by salcan »
