Author Topic: JTK sliders spacebar stems  (Read 4526 times)
Offline PleaseBeMyFriend
  • formerly honsoo
  • reddit /u/PleaseBeMyFriend
« on: Sat, 13 May 2017, 13:03:00 »
Has anyone found out a more permanent (for lack of a better word) solution for the stem issue when using topre to MX sliders?
Offline scwoopz
Re: JTK sliders spacebar stems
« Reply #1 on: Sat, 13 May 2017, 13:04:56 »
Holes in the case
ortho or shmortho
  • formerly honsoo
« Reply #2 on: Sat, 13 May 2017, 17:36:02 »
Holes in the case
I know holes in the case work for the modifiers, but I meant specifically for the spacebar stems.
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #3 on: Sat, 13 May 2017, 18:01:11 »
Holes in the case
well a spacebar is provided with them for full functionality, because finding mx ones ot match keysets in 6u length is incredibly difficult anyway
however assuming you have a good amount of 6u mx spacebars and wish to use them, you can mod the spacebar stab to be costar
  • formerly honsoo
« Reply #4 on: Sat, 13 May 2017, 18:13:35 »
Holes in the case
Thank you for the reply bunny!
How would you go about modding it with costar stabs?
Offline BunnyLake
  • X
« Reply #5 on: Sat, 13 May 2017, 18:15:09 »
Holes in the case
I haven't done it since the nova first came out, I'll see if I can dig out that board from storage and take pics as soon as possible
  • formerly honsoo
« Reply #6 on: Sat, 13 May 2017, 18:18:03 »
Holes in the case
Okay, I would really appreciate that!
  • formerly honsoo
« Reply #7 on: Mon, 15 May 2017, 19:20:06 »
Holes in the case
Hey bunny - did you have time to get those pics :o
