Author Topic: Highest quality (not metal) opaque case?  (Read 1705 times)
Offline Encabulator
« on: Tue, 16 May 2017, 00:12:23 »
I see tons of cases on the market but when it comes down to your options it's flat/sculpted and aluminum/acrylic/plastic. I really like how acrylic cases sound, but all they ever come in is frosted which I really have no use for. What is the highest quality 60% case one could get that is opaque and not a metal? Painting might be an option but it's always better if it's manufactured the way. Thanks!
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Offline Potatomonkey
  • Tsangan best row
Re: Highest quality (not metal) opaque case?
« Reply #1 on: Tue, 16 May 2017, 00:30:32 »
You can get an opaque acrylic case.
Offline Tactile
« Reply #2 on: Tue, 16 May 2017, 01:01:42 »
Poker 2 style cases are available almost anywhere. I've seen them in black, white, and purple and there are probably other colors as well.
168505-0
REΛLFORCE
Offline Encabulator
« Reply #3 on: Tue, 16 May 2017, 01:14:40 »
Where have you seen these?
