Author Topic: Flipped Space  (Read 28591 times)
Flipped Space
« on: Thu, 18 May 2017, 01:03:40 »
So after 2+ years of flipping my spacebars I tried typing on a board without a flipped space and it feels terrible, I hit right between B & M and directly on the leading edge of the spacebar's top surface. I'm sure my exact space hit placement has changed a bit after flipping but at this point I don't think I could go back.
Offline Encabulator
Re: Flipped Space
« Reply #1 on: Thu, 18 May 2017, 07:37:21 »
I hate flipped spacebars. When I flip my spacebar it feels like I have to put my wrists at an upward angle.
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Re: Flipped Space
« Reply #2 on: Thu, 18 May 2017, 08:05:47 »
It depends on the angle of the keyboard and how you're sitting on the chair. I have my work board flipped, but one day I raised my seat really high and oddly found the space bar too angled. So I flipped it back to normal and it felt...great.
Then I lowered my seat again and re-flipped the bar.
Offline DaBubbs
Re: Flipped Space
« Reply #3 on: Thu, 18 May 2017, 09:12:52 »
I tried flipping mine for a day and I just couldn't stand it. Like Encabulator, I felt I had to change my typing posture and it felt very unnatural and annoying.
From the people I know that like flipped spacebars, you either just like it or you don't.
When you are dead, you don't know that you are dead. It is difficult only for the others.
It is the same when you are stupid.
Offline Targa-TV
Re: Flipped Space
« Reply #4 on: Thu, 18 May 2017, 09:22:37 »
I know your pain Joey.
I felt very comfortable typing on a flipped spacebar + wrist rest with the Varmilo and the Filco but I can't flip the spacebar of the G80.
Problem is, I am now used to hit the spacebar with my thumb's knuckle with an oblique, downward stroke so my thumbs hurt a bit after prolonged typing with the G80. Wish I could flip the damn spacebar. I tried raising the wrist rest but it doesn't help.  :(
« Last Edit: Thu, 18 May 2017, 10:30:29 by Targa-TV »
Filco MJ2 Black - MX Red | VA88M - MX Brown | Cherry G80-3000 -
  MX Blue | Cherry G80-3000 - MX Black | XD75re - MX Silent Red
[image]http://i.imgur.com/our8YUc.png[/image]
Offline Entropia
Re: Flipped Space
« Reply #5 on: Thu, 18 May 2017, 10:13:07 »
I always use my left thumb for the spacebar. I found out this idea of flipping the spacebar some months ago. At first I wasn't aware of what what the purpose of doing this, until I tried. Now, with my Leopold FC980M using a flipped spacebar feels so much more natural and comfortable. It may look weird on the keyboard, but it feels right. It's such a simple and brilliant idea!
Offline diiiP
Re: Flipped Space
« Reply #6 on: Thu, 18 May 2017, 14:10:20 »
for me it depends mainly on my wrist.
When lifted of the table or with a wristrest the normal oriantation works great.
With the wrist on the table flipped is more comfortable.
Re: Flipped Space
« Reply #7 on: Thu, 18 May 2017, 23:53:10 »
Sounds very similar to how I hit space
No wrist rest for sure makes the difference between flipped and not flipped more obvious but even with a wrist rest I still don't like not flipped.
Offline a_ak57
Re: Flipped Space
« Reply #8 on: Fri, 19 May 2017, 07:24:19 »
I keep my wrists up so I keep the bar in normal orientation.  Though even if I bent my wrists, I'd still use normal because flipped bars look so, so awful.
Offline Sissy
Re: Flipped Space
« Reply #9 on: Fri, 19 May 2017, 07:29:13 »
Flipped spacebars are agaisnt the rules and keyboard police will arrest you for doing it.
Be warned.
I find actually typing with a flipped bar to be kinda off putting and prefer to type with it the right way.
Offline Targa-TV
Re: Flipped Space
« Reply #10 on: Fri, 19 May 2017, 07:31:57 »
You prefer uncomfortable typing to the aesthetic of a flipped spacebar?
Offline LevelSteam
Re: Flipped Space
« Reply #11 on: Fri, 19 May 2017, 07:44:42 »
Yup same here. I can't stand the feeling of my spacebar being flipped. It throws off all of my typing.
Offline a_ak57
Re: Flipped Space
« Reply #12 on: Fri, 19 May 2017, 08:54:13 »
TBH I don't find a normal bar uncomfortable even when I try typing with my wrists bent.  Though maybe people are typing with even worse posture than I assume or I just tap the bar more lightly than others or something.
Offline _PixelNinja
  • C=Q/V=ε(A/t)
Re: Flipped Space
« Reply #13 on: Sun, 21 May 2017, 11:47:39 »
If you need to flip your spacebar then you need to review your position/ergonomics in front of your desk.
Re: Flipped Space
« Reply #14 on: Mon, 22 May 2017, 01:22:49 »
Have any facts to back this up?
I use 3 different desks with 3 different chairs and the height difference changes from desk to desk, I always prefer a flipped space.
Offline _PixelNinja
  • C=Q/V=ε(A/t)
Re: Flipped Space
« Reply #15 on: Mon, 22 May 2017, 06:06:19 »
What facts? It's basic ergonomics. You should be positioned relative to your desk so that your elbows form a 90° angle, your forearms and wrists should be strait and your hands should hover above the keyboard (and a wrist-rest is for resting the palm of your hands when your are not typing). All in a relaxed position. Unless one has some kind of deformity, in this position, your thumbs should fall down on the top of the space bar — not on the edge/angle. If so, you are doing it wrong.
Not saying it is your case; there might be something else in your setup(s) that could be a potential issue, but for instance a lot of people I see typing with inverted spacebars tend to have their wrists at an angle, wresting them on the desk while typing. That's asking for trouble in the long run if you spend a lot of time in front of the computer.
« Last Edit: Mon, 22 May 2017, 06:08:40 by _PixelNinja »
Offline Targa-TV
Re: Flipped Space
« Reply #16 on: Mon, 22 May 2017, 08:09:46 »
Then I am doing it wrong because my goodness keeping my arms at 90° angle with forearms and wrists straight for 4+ hours in front of my computer HURTS AS F*. When I'm transcribing lessons for example I'm constantly retreating (<-there is be a better word for this but i can't recall right now) my forearms to my chest and rubbing my wrists every time the speaker pauses or stammers. At a 90° angle with straight forearms and wrists... Man, seriously, try to keep that position for hours on end and report back and if you don't feel pain please tell me what's your magic. It hurts as all f***s.
« Last Edit: Mon, 22 May 2017, 08:11:33 by Targa-TV »
Offline _PixelNinja
  • C=Q/V=ε(A/t)
Re: Flipped Space
« Reply #17 on: Mon, 22 May 2017, 08:45:10 »
Done it for many years without pain. And that is the important point — if it hurts, then something is wrong.
Re: Flipped Space
« Reply #18 on: Mon, 22 May 2017, 13:17:45 »
I still think it has more to do with how you hit space, my typing posture is decently similar to what you describe (my wrists aren't angled when I type). If you hit space straight down regular will be your choice, if you more slide your thumb off space to actuate it flipped will feel better.
For example, keysets with a flatter space like DSA, SA, or the occasional weird vintage profile don't bother me at all but I really only use Cherry profile or the OEM HHKB profile so I always flip.
Offline Vigrith
Re: Flipped Space
« Reply #19 on: Tue, 23 May 2017, 07:55:46 »
I only flipped space bars like 6 months ago, I mostly use DSA/XDA sets so with those there's no flipping obviously, though when I do use GMK/SA I rather have them flipped - I have no issue/pain/etc having them on the right away, I've used keyboards for 6-12 hours a day for decades now but it does feel much more natural to have it flipped. Go figure. Might as well do it, I see no problem in doing so personally.
Re: Flipped Space
« Reply #20 on: Tue, 23 May 2017, 21:50:44 »
I remain unable to flip the space bar on this keyboard.
Re: Flipped Space
« Reply #21 on: Wed, 24 May 2017, 17:55:11 »
Maybe you should ditch the ancient IBM.
Re: Flipped Space
« Reply #22 on: Thu, 25 May 2017, 21:57:31 »
Nope.
Re: Flipped Space
« Reply #23 on: Thu, 25 May 2017, 22:07:45 »
Nope.
When I get a 4704 I'll figure out a way to flip the space.  :p
Re: Flipped Space
« Reply #24 on: Sun, 04 June 2017, 22:16:30 »
Nope.
Why?
Offline ArchDill
Re: Flipped Space
« Reply #25 on: Sun, 04 June 2017, 23:05:32 »
I tried to do flip space bar and it is just so uncomfortable for me. I can not live with it.
Offline pab
  • Dvorakian Nightmare
Re: Flipped Space
« Reply #26 on: Sun, 04 June 2017, 23:07:33 »
Same 100%. Not to mention I also think it looks really bad.
Re: Flipped Space
« Reply #27 on: Sun, 04 June 2017, 23:11:19 »
Why?
Wait, is the 4704 space symmetrical? I guess I never noticed how flat it looks, there may be no need to flip it.
Re: Flipped Space
« Reply #28 on: Mon, 05 June 2017, 05:04:48 »
Why?
There is never any need to flip any space bar.
Re: Flipped Space
« Reply #29 on: Mon, 05 June 2017, 05:15:01 »
Offline SBJ
  • Tactile pls
Re: Flipped Space
« Reply #30 on: Mon, 05 June 2017, 07:06:47 »
During my time here I've heard of flipped spacebars before so I decided to try it.
I just couldn't get used to it. I don't know if many many years of typing with a regular spacebar has ruined it for me. I simply couldn't get comfortable with it and I was making mistakes.
Might have something to do with my awful posture or just the way that I type. I'd probably need someone way more knowledgeable than me looking at me type so he could correct all the mistakes I was making. :p
Re: Flipped Space
« Reply #31 on: Mon, 05 June 2017, 21:54:24 »
Or maybe it's because you are a normal person, and flipped space bars are totally deviant.
Offline iliptikal
Re: Flipped Space
« Reply #32 on: Mon, 05 June 2017, 23:32:18 »
I had never tried it until recently, and now I use mine flipped too.  I just like the way my thumb hits the key much better.
Re: Flipped Space
« Reply #33 on: Tue, 06 June 2017, 05:35:01 »
:-X
Offline SBJ
  • Tactile pls
Re: Flipped Space
« Reply #34 on: Tue, 06 June 2017, 07:51:26 »
Yes... Normal. Indeed.  :))
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
Re: Flipped Space
« Reply #35 on: Tue, 06 June 2017, 07:57:16 »
Recently converted everyone in my office that uses a mech to flipped, muahahahaha
Re: Flipped Space
« Reply #36 on: Tue, 06 June 2017, 08:02:39 »
Good work :thumb:
Offline kolec94
Re: Flipped Space
« Reply #37 on: Tue, 06 June 2017, 09:57:13 »
I like my space-bar flipped just because i feel like i need to purposefully  click it not just barely press it and get more spaces then i need.
kbparadise v60 blues
Re: Flipped Space
« Reply #38 on: Tue, 06 June 2017, 21:59:25 »
So these deviants who flip their space bars - do you flip the rest of the bottom row too?  If not, have you been tempted to?
Re: Flipped Space
« Reply #39 on: Wed, 07 June 2017, 13:21:19 »
I don't but that's because only my thumb hits at an angle where flipping makes it more comfortable to use, if space wasn't the only key I hit with my thumb then maybe I'd try flipping other keys.
Offline Vibex
  • Love y'all
Re: Flipped Space
« Reply #40 on: Wed, 07 June 2017, 13:26:21 »
On my Gon HHKB I have flipped the spacebar as well as the two 1.5u keys directly next to it. I haven't flipped the two 1u keys on the far ends of the bottom row though. Since I hit those keys with my pinky and not my thumbs, it just doesn't make sense to flip them.
Re: Flipped Space
« Reply #41 on: Wed, 07 June 2017, 22:30:22 »
Interesting responses - thanks - which lead me to wonder if it is shape of thumb or dexterity of thumb movement that makes an unflipped space bar uncomfortable for a small percentage of users.
Offline KACHAKEYS
Re: Flipped Space
« Reply #42 on: Tue, 27 June 2017, 01:58:13 »
I personally have been typing on flipped space for the past two and a half years and I cant even use a normal  keyboard now, Same with swapped Backspace/Backslash.
I feel like an ape when I use a friends keyboard that doesnt have both of these.
Re: Flipped Space
« Reply #43 on: Tue, 27 June 2017, 22:45:31 »
How I feel whenever I use qwerty now  :blank:
Offline Vibex
  • Love y'all
Re: Flipped Space
« Reply #44 on: Tue, 27 June 2017, 22:59:05 »
Yeah I know that feel. Such a pain, but I'll never switch back.
Re: Flipped Space
« Reply #45 on: Tue, 27 June 2017, 23:03:39 »
Oh yeah, I'll never switch back
Now I just carry a board with me everywhere I go
Re: Flipped Space
« Reply #46 on: Tue, 27 June 2017, 23:17:08 »
Just dropping in this thread to say that I only use flipped space anymore. It's so much more comfortable than unflipped.
Offline OneNightFriend
Re: Flipped Space
« Reply #47 on: Sat, 01 July 2017, 15:40:51 »
I too am a flipper but I haven't tried yet on the VE.A yet. At work currently using dsa so no flipping needed. Maybe I'm an impostor?
Offline NAV
  • Formerly A_Vicarious_Death
Re: Flipped Space
« Reply #48 on: Sun, 02 July 2017, 00:31:12 »
flipped is best
Offline davkol
  •  Post Editing Timeout
Re: Flipped Space
« Reply #49 on: Mon, 03 July 2017, 05:02:58 »
I don't like a flipped _spacebar_ but flip keys like modifiers (which may include the key mapped to "space" in the end).
