Author Topic: Se-Jin SKM-1030?  (Read 5844 times)
Offline silverpanda94
Se-Jin SKM-1030?
« on: Fri, 19 May 2017, 13:48:21 »
So I work for a small IT firm, and when we go do hardware upgrades for our clients, we often bring back their old equipment so it can be picked up for recycling.  This includes many keyboards, though they're pretty much all just plain 'ol dome boards.  Except for this one my boss brought back from a customer.  I asked him if I could take it home and he said sure.
So I know almost nothing about this board.  It's a Se-Jin SKM-1030.  I did a google search on it and could hardly find anything on it.  And when I searched on here, I found nothing at all for anything by Se-Jin at all (unless I'm just not using the search function right.  I'm still kind of a noob here).  Do you guys know anything about this? What I do know and can show in pics is that it has Futuba clicky switches, flip out feet with two height options, cable routing, and has an AT connector at the end of the coiled cable.  While I haven't been able to actually plug it in and try it out, I actually really like the key feel.  The keys appear to be double-shot PBT, but I'm not 100% sure.  The switches feel pretty smooth and kinda light.  Interestingly, the click is louder on the upstroke than the downstroke.
I'll post some pics below.  Do you guys know anything about this board? I'm curious to learn more about it.  Hopefully I'll be able to test it soon.
Topre Realforce RGB // IBM Model M (1989) // Razer Ornata Chroma // Cherry MultiBoard MX 8100 // Microsoft Natural Keyboard 4000 (at work)
Offline balotz
Re: Se-Jin SKM-1030?
« Reply #1 on: Fri, 19 May 2017, 14:01:49 »
I have a couple of these boards. I haven't been able to figure out what material the keycaps are made from as they exhibit characteristics of both ABS and PBT.
Futaba's suffer from a problem where the click is lost over time - even in 'new' old stock boards. The reason for this is that the rubber dampening mat inside the switch becomes warped upwards, preventing the plate spring from reaching its full range of motion.
I've managed to fix this problem in my boards, permanently restoring the original tactility, by pressing down very hard on each slider with a cross screwdriver and holding for about 5 seconds. The switches in the SKM-1030 are mounted on a metal plate.
« Reply #2 on: Fri, 19 May 2017, 14:19:46 »
Huh! Very interesting! I'll definitely try that then to see if it makes the switches feel more tactile.  This is my first time ever encountering Futuba switches.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #3 on: Fri, 19 May 2017, 14:56:37 »
https://deskthority.net/wiki/Sejin_Electron
It's "Sejin" now, but it's also been "Se-Jin" clearly.
Bore Awards
Offline svatech
« Reply #4 on: Mon, 22 May 2017, 23:43:08 »
I can help you replace the connector on it
Sent from my SCH-I545 using Tapatalk
« Reply #5 on: Tue, 23 May 2017, 10:29:30 »
sounds good
« Reply #6 on: Thu, 25 May 2017, 15:52:49 »
Well I can say now after letting svatech replace the AT connector on it with a PS/2 connector for me (thanks a ton btw) I can actually give some thoughts now that I've used it in regular day to day operation.
It's not a bad feel.  Keys are mostly pretty smooth.  The clicky sound is pretty loud and kinda pingy, but not as high pitched as MX Blues.  The tactility is kinda soft, but apparently this board loses its tactility over time due to the switches.  I might try balotz's suggestion on how to restore the tactility down the road.  All in all, I enjoy it.
One thing I found kinda odd was the flip out feed on the back.  They are EXTREMELY angled.  They have two settings, and the lower of the two is already pretty steep.  The highest setting is so steep that I don't see how anyone could consider it comfortable to type on.  Kind of a strange design choice if you ask me.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #7 on: Thu, 25 May 2017, 19:18:14 »
I have a 1032 and a couple 1032's. My 1030 is actually not bad to type on, steel plate and the Futaba' linears are still clean. Caps are ABS DS imop.
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline balotz
« Reply #8 on: Fri, 26 May 2017, 02:31:18 »
Are you certain your 1030 has linear switches - i.e. no click at all?
« Reply #9 on: Fri, 26 May 2017, 09:35:59 »
Idk if this would be the case with the 1030, but I read that with the 1040, some came with linear and some came with clicky.  So it's possible that there were clicky and linear versions of the 1030.  I know for a fact mine is definitely clicky.  it's just not as tactile as it should be.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #10 on: Fri, 26 May 2017, 21:00:41 »
I would have to grab out of closet to check? Isn't the 1030 older than the 1032? I remember them being linear, so will need to check?
Offline balotz
« Reply #11 on: Sat, 27 May 2017, 12:29:17 »
The SKR-1032 is a rubber dome board. The 1030 has an SKM prefix, indicating it's mechanical - I'm fairly sure there isn't a linear version of this futaba switch. Because of the almost uniform loss of tactility, some of them have a near-linear feel, but they came out of the factory clicky. This loss of tactility isn't due to use, but to age.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #12 on: Sat, 27 May 2017, 13:24:30 »
I pulled my 1030 out and it was most definitely not clicky, nor ever was. If age has anything to do with the feel of the switches it possibly might have been tactile at one time- but most definitely linear at present where they all feel the same too me.
The 1032 are hybrid- part rubber dome for sure, but still not bad to type on.
My 1030 is branded with Magitronic and is really pleasant to type on :thumb:
I think I have listed in some keyboards I own under.........MORE, below
Now that I think abt it I have a old Packard Bell that is clicky with either Futaba's or SMK?
« Last Edit: Sat, 27 May 2017, 13:35:45 by terrpn »
Offline balotz
« Reply #13 on: Sun, 28 May 2017, 08:55:02 »
Interesting - would you mind sharing a photo of one of the keyswitches? The Packard Bell is most likely Futabas as well.
  • RIP
    • Boring twaddle
« Reply #14 on: Sun, 28 May 2017, 11:59:42 »
So far as I know, this observation remains controversial. If the switches are only weakly tactile to begin with, and the tactility can fade over time, then how can you be 100% certain that the switches were linear from new?
My current interpretation of the specifications is that MA41 series is clicky and MA42 series is linear:
https://deskthority.net/wiki/Futaba_MA_series#Specifications
There must be a catalogue out there somewhere that makes this clear. In the meantime, I found this, from 1993:
https://books.google.co.uk/books?id=jMKfH6i9OcYC&pg=PA433&lpg=PA433&dq=Sejin+keyboard+catalog&source=bl&ots=nd1M45BJBM&sig=4jE4Z5HdJkodRRPXw10ga_m1g9c&hl=en&sa=X&ved=0ahUKEwj2sr_q_JLUAhVBDsAKHf2PBQsQ6AEIUTAF#v=onepage&q=Sejin%20keyboard%20catalog&f=false
"Lifetime Guarantee on Keycap Legends"
Bore Awards
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #15 on: Sun, 28 May 2017, 12:10:16 »
Well I was assuming from an earlier post abt the switches being clicky and over time they weakened? My opinion is that they are linear and came linear from the factory- which i was trying to assert that they are all uniform in feel to me? Feel like mx reds as far as comparison...... :blank:
The clicky ones in my Packard Bell could be Futaba, but feel more like the clicky SMK's in my vintage Laser?
  • RIP
    • Boring twaddle
« Reply #16 on: Sun, 28 May 2017, 13:22:56 »
I don't know, you'll have to check them and find out.
The only way to be sure with Futaba is to open a switch, and they're sealed shut.
Bore Awards
