Author Topic: Need help for my first keyboard build  (Read 1682 times)
Offline MarkL97
« on: Sun, 21 May 2017, 10:56:14 »
First of all, i have no idea if it is the right place for topic. If it isn't, i apologize.
Hello guys, this is my first time building a keyboard (XD60). I soldered all the switches on the PCB and everything worked perfectly. Then, I found out that the left Ctrl, left Fn0, and left Alt switches were in wrong positions. Then, I de soldered them and soldered them into the correct positions. After that, everything went wrong.
Photos of the layout and PCB
http://imgur.com/a/1W8QZ
All the red keys and green keys have no response when I press them.
When I press a blue key, it will show a green key on the same row. For example, when I press “8”, it will show “5”
This is the first time I have ever soldered anything. I made some mistakes. When I was de soldering the left Fn0 key, I lifted both pads. Other than that, I have no idea what I have down wrong.
Please help, I don’t want to give up on this keyboard.
Thank you.
