Author Topic: [GB] NL–Bullet <<100% shipped, extras will be up Soon™>>  (Read 72877 times)
Offline jebbra
  • jebbra.net
ORDER CLOSED
This is a Group Buy for Planck's aluminum high profile case: NL–Bullet
The interest check can be viewed here >> https://geekhack.org/index.php?topic=85663.0
168886-0
Specs
– High profile casing for 40% ortholinear board
– Material: Aluminum T6061
– Finish: Anodize
– Dimension: 238 x 86 x 20 mm
– Plate material: Stainless Steel / Brass
– Plate dimension: 228 x 76 mm
– 7x M2 Hexscrew
– 5x 8 x 2 mm Rubber feet
– 3x 16 x 8 mm Rubber feet
– Manufactured in Indonesia
Please note that this case is NOT COMPATIBLE WITH OLKB PLANCK PLATE
Price
$100
– Including aluminum case, SS brushed plate, rubber feet, and screws.
– Excluding PP fees and shipping.
Upgrades
– SS Black EDP plate +$7
– Brass plate +$15
– OLKB Planck PCB +$36
Anodize Color
168888-1
Gallery
168890-2
168892-3
168894-4
Timeline
– Groupbuy ends 5th June 2017
– Payment deadline 11th June 2017
– Production 10-14 weeks
Order changes
Do not PM me for changes, please send email to northlab.id[at]gmail[dot]com instead. This way I can keep the messages neater.
ORDER CLOSED
« Last Edit: Thu, 14 June 2018, 22:37:21 by jebbra »
Offline jebbra
  • jebbra.net
« Last Edit: Tue, 06 June 2017, 21:05:31 by jebbra »
Offline jebbra
  • jebbra.net
Re: [GB] NL–Bullet Case -- Aluminum High Profile Casing for Planck.
« Reply #2 on: Mon, 22 May 2017, 07:19:54 »
.reserved.
Offline theillumedpanda
  • Don't point that gun at me - I'm an unpaid intern!
« Reply #3 on: Mon, 22 May 2017, 16:43:34 »
Approval bump! Good luck with the GB.
Offline teeseeuu
« Reply #4 on: Mon, 22 May 2017, 17:14:53 »
I'm in! Went gold. Maybe should have done white. Great price for the buy and the PCB
Offline futurecrime
  • Get Zooted
« Reply #5 on: Mon, 22 May 2017, 19:14:13 »
Man I wish I hadn't jumped on the Massdrop Planck GB... reckon I'll sell it when it arrives and get on the Anvil GB. How soon do you think that will start after Bullet ends?
Offline aznreaper
« Reply #6 on: Mon, 22 May 2017, 19:14:35 »
Oh, good to see the buy going, great price. How does the white anoidizing work, didn't think it was really possible? Also, what is the black EDP plate?
Offline jebbra
  • jebbra.net
« Reply #7 on: Mon, 22 May 2017, 19:37:50 »
Thanks man!
Anvil will be made to fit OLKB plate so you can sell just your casing from previous Planck's GB. Honestly I still don't know when exactly Anvil will start, but one thing for sure it is right after Bullet.
Thanks mate, really appreciate your participation :thumb:
It's not white like the pic I post on OP (the one on OP is powder coated). I write it 'silver white' because it's less silver compared to the silver of MacBook. EDP is powder coat process, the texture is a bit grainy, it usually used on firearms/airsoft gun. I'll post pics of the plate today, just got them in.
Offline aznreaper
« Reply #8 on: Mon, 22 May 2017, 21:06:23 »
Oh, just noticed that the first post says the PCB is 35, but the google form says 36
Offline ns90
« Reply #9 on: Mon, 22 May 2017, 23:00:45 »
Oooooh. Now which color. Decisions, decisions.
Offline nao
    • NAO
« Reply #10 on: Mon, 22 May 2017, 23:41:52 »
Joined the GB and waiting for Anvil.
Offline senter
« Reply #11 on: Tue, 23 May 2017, 02:04:50 »
Gallery is  good like white color Micro arc???
Offline jebbra
  • jebbra.net
« Reply #12 on: Tue, 23 May 2017, 02:33:08 »
Good catch, my bad, already corrected it. It is $36 ;D
If you don't have spesific keyset in mind, I said go for spacegray, it's the most versatile one :thumb:
Appreciate it mate, make sure you follow the newsletter!
I'm sorry seems like I don't get what you wanna say. Using your own language is better since I can google translate it :)
Offline r5d
  • Reddit: /u/thisman
« Reply #13 on: Tue, 23 May 2017, 02:40:52 »
HYPE!!!  ;D  ;D  ;D
I like keyboards
Offline garbo
« Reply #14 on: Tue, 23 May 2017, 03:05:12 »
I actually liked the white powder coat on your prototype a lot and would go for that if it were available.
The lightest anodise sample seems pretty good in the picture but I feel I might find it too silvery/grey in person. Do you have the sample available to possibly take additional pictures in different lighting conditions or something?
Offline ShishKabobJerry
« Reply #15 on: Tue, 23 May 2017, 06:02:51 »
Wow really pretty case! Goodluck with the GB!
Offline jebbra
  • jebbra.net
« Reply #16 on: Tue, 23 May 2017, 06:20:08 »
HYPE!!!  ;D  ;D  ;D
I'M HYPED TOO  :p
I'm thinking to add the powder coat option too since it had been researched so why not offer it? Will properly photograph the chips again tomorrow and update the form. And you're right, if white is what we seek, no anodize will come close to white powder coat!
Thank you! Appreciate your kind words :cool:
Offline futurecrime
  • Get Zooted
« Reply #17 on: Tue, 23 May 2017, 06:30:03 »
Great stuff. Thanks for the info man. Good luck with this one, it's a stunner!
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #18 on: Tue, 23 May 2017, 07:39:21 »
I believe senter is asking if the white color is done with micro arc oxidation (also known as Plasma electrolytic oxidation) which is a similar process to anodizing.
Offline oluigenuma
« Reply #19 on: Tue, 23 May 2017, 11:21:59 »
GMK Dolch better on a black or space gray case?
Offline nao
    • NAO
« Reply #20 on: Tue, 23 May 2017, 12:43:20 »
Personally, I think space gray one is better.
Offline jebbra
  • jebbra.net
« Reply #21 on: Tue, 23 May 2017, 22:24:24 »
Ah I see. The one on gallery is done with Powder Coat, not anodize. The only way to achieve real white on aluminum is through powder coat.
Yep space gray is better. For a rule of thumb, generally it always be better to match the case color with alpha color, instead of modifier color.
Offline jebbra
  • jebbra.net
« Reply #22 on: Tue, 23 May 2017, 22:39:55 »
Some update:
1. This is the plate options
169060-0
This is the Black EDP plate details
169062-1
2. I will include powder coat for finish choice, if you want it just hold on until tomorrow until I update the form. For you who already fill the form, you can contact me if want to change
Missing here is the red, will update tomorrow
169064-2
This is the texture, black and white are more matte, blue and green are orange-skin
169066-3
Offline teeseeuu
« Reply #23 on: Wed, 24 May 2017, 07:13:50 »
I'm going to email you a change to my order. That EDP is too good!
Offline ChitownM2
« Reply #24 on: Wed, 24 May 2017, 07:14:19 »
When your say "upgrades" for the plate does that mean you will get that plate instead of the regular SS one? Or are they actually "extras" meaning you get both?
Offline oluigenuma
« Reply #25 on: Wed, 24 May 2017, 08:00:57 »
It's just an upgrade, not an extra.
Any idea how much shipping to europe/germany will be?
Offline cr0n1c
« Reply #26 on: Wed, 24 May 2017, 18:00:35 »
So is there just a universal plate that can handle both MIT and Grid layouts? I don't see a distinction in the form. If this has already been asked I apologize as I didn't see it.
Offline aznreaper
« Reply #27 on: Wed, 24 May 2017, 23:32:24 »
Those plates look interesting, what layouts are those plates made for?
Offline Latin00032
« Reply #28 on: Thu, 25 May 2017, 08:21:55 »
When is the white painted option going to be added to the form?
Offline jebbra
  • jebbra.net
« Reply #29 on: Thu, 25 May 2017, 10:45:50 »
The first, you are not going to get additional plate. But you can add more plates/PCB if you write it on the note :)
Done!
The plate we will get is univerasl one, I designed it myself to accomodate Grid, MIT (but it can only use Cherry PCB stab), and even 1.25u bottom row—yes OLKB PCB support 1.25–1.25–1.25–1.25–2–1.25–1.25–1.25–1.25 or 1.25–1.25–1.25–1.25–1–1–1.25–1.25–1.25–1.25 bottom row!
Sorry if the Black EDP make it looks like the plate have options, the Black EDP is OLKB plate which I use for EDP sample.
I've updated it now, the photograph will added later after I get the red powder coat (I left it at my friend's house..)
« Last Edit: Thu, 25 May 2017, 10:48:28 by jebbra »
Offline elfick
  • Can I get Colemak and a side of fries with that?
Is the plate cut for both MX and Alps switches? It looks like it is is but I couldn't find anything specifically mentioning it.
Offline yosi1sland
When will my billing email be sent?
Offline jebbra
  • jebbra.net
Yes it support both MX and Alps variants! Sorry for not mentioned it before. Now I already updated this info, thx!
The quotation will be sent after the form closed, which is between 6th – 11th June :)
Offline Kafka
  • i like clean things
God I'm excited for the Anvil.
Offline roostrc0gburn
  • its just plastic
i have been following this project for a while. very happy to see this project moving forward. has the purple option been removed? seems like it would be easy to get in powdercoat
Offline Rolian
Hi guys I want to buy this case to do my first  assembled board and I have some questions. what do I need to finish the board? just the switches? If so is this Zealio compatible ?
Offline oluigenuma
You will need switches, keycaps and a cable. Yes the plate is Mx and Alps compatible, so it does support zealios which are a mx variant.
Offline Rolian
Allright thanks man
Offline yosi1sland
Can not you send me a payment message sooner?
I want to pay in advance due to circumstances.
I want to make the payment as soon as possible.
« Last Edit: Sat, 27 May 2017, 21:12:47 by yosi1sland »
Offline jebbra
  • jebbra.net
Sorry I just see your post, already email you regarding this  :thumb:
Offline yahei
« Reply #40 on: Sun, 28 May 2017, 14:05:33 »
Do you reply when accepting a case color change request?
I sent it from the left mail icon, but I have not received a reply.
Have my request been accepted?
Offline jebbra
  • jebbra.net
« Reply #41 on: Mon, 29 May 2017, 00:15:05 »
Sorry seems like I miss your email. Your order now is Powder Coat White, SS Brushed plate, +PCB, is this right?
Offline yahei
« Reply #42 on: Mon, 29 May 2017, 07:15:29 »
Yes. Thank you very much.
  • its just plastic
purple?
Offline Latin00032
Allright thanks man
Keep in mind, you may need a 2x cherry plate mount stab depending on the layout.
Which layout are you using?
Offline Tallypat
Do you usually send an email in confirmation of a change in the order? Just wanna make sure I get that powder coat white version!
Offline jebbra
  • jebbra.net
Yes I inform via email when doing changes, maybe I skipped you, sorry. But your order already sit with Powder Coat White so all set and good!
Allright thanks man
I want to confirm that the plate only accept Cherry PCB-mount one. Sorry I forgot to to highlight this detail!
Offline Rolian
Is the stabilizer really needed I mean I read that many people don't use it with the 2u spacebar- Am I right?
Offline climbalima
  • likes building stuff
I never use stabs on planck builds
Sent from my SM-G920V using Tapatalk
Offline Latin00032
I didnt have it on my ergodox and it bothered me. You can get away without using it though.
