Author Topic: Critique my layout  (Read 2446 times)
Offline SpectreiiI
  • Scribe
Critique my layout
« on: Tue, 23 May 2017, 00:01:04 »
Yes, it is based off of the HHKB, with a few modifications specifically suited for coding. What do you think?
Re: Critique my layout
« Reply #1 on: Tue, 23 May 2017, 01:00:35 »
What's the point of increasing the left mods by 0.25u and changing the right shift split?
The bottom row is fine but the other changes will just make finding keysets hard.
Offline nmur
  • ಠ_ಠ
« Reply #2 on: Tue, 23 May 2017, 01:52:52 »
^ yeah, unless you're planning on using a custom array of blank DSA keys, you're going to have a lot of issues finding caps
a suggestion to maintain keycap compatibility would be to perhaps start with the hhkb layout, and just use a split right shift (like ISO, but with the shift on the left of the split) and a split spacebar
« Reply #3 on: Tue, 23 May 2017, 02:11:49 »
My version modified to make it much more keyset compatible
168958-0
Offline ArchDill
« Reply #4 on: Tue, 23 May 2017, 02:14:25 »
Yeah, I would go with this one for sure. The original layout would be such a hassle in the long run.
Offline SpectreiiI
  • Scribe
« Reply #5 on: Tue, 23 May 2017, 07:57:23 »
  After a good night's sleep, I agree with you on the left mods, but I need that 1.25u right Fn button.
« Last Edit: Tue, 23 May 2017, 08:00:07 by SpectreiiI »
