Author Topic: Broken trackpoint stem  (Read 13007 times)
Offline kousuke
« on: Tue, 23 May 2017, 09:01:06 »
Greetings,
My trackpoint stem had broke off - i'm wondering if this is repairable or I actually have to replace the entire module?
Not quite sure where I can even find spare parts - it's a Bourns 3722B based trackpoint module - KPH0035 IBM USB spacesaver keyboard
Thanks in advance
Offline luns
Re: Broken trackpoint stem
« Reply #1 on: Fri, 08 March 2019, 12:33:42 »
Greetings,
Thanks in advance
Don't know if you're still looking for leads, but for the record, the IBM KPD8923 keyboard uses the identical trackpoint module.
