Author Topic: Keyboards similar in style to the TX 1800?  (Read 2156 times)
Offline Mechanical Atom
« on: Tue, 23 May 2017, 10:54:47 »
Hey guys, so the wifey really wants a TX 1800, however it looks like the chance to buy them doesn't come up to often. When it comes to other options i don't know too much about full size keeb kits. I've tried to do some research but just can't find much else like it.
Basically she wants a retro style case, but something that isn't ALPS based so i can change the switches to something like cherry clears or zealios.
Kickin\' it old school: DELL AT-101 14140 - Pink ALPS // FILCO Majestouch "Otaku" (Tenkeyless) w/ Blue Cherrys
Offline kawasaki161
Re: Keyboards similar in style to the TX 1800?
« Reply #1 on: Tue, 23 May 2017, 10:59:33 »
You could try still getting on it: https://geekhack.org/index.php?topic=88916.0
Otherwise you are very limited with kits, maybe the Peach? But I think that might be too modern, it ended 3 days ago, but maybe you can just ask https://geekhack.org/index.php?topic=89358.0
Offline avid
« Reply #2 on: Tue, 23 May 2017, 11:00:55 »
Leopold Fc980c (topre) or Fc980M (mx)? Othervise you can buy Cherry g80 1800.
Offline SpectreiiI
  • Scribe
« Reply #3 on: Tue, 23 May 2017, 14:42:48 »
Dolch G80-1813.
« Reply #4 on: Wed, 24 May 2017, 10:52:14 »
Thanks for the options guys, i really like the Dolch, but she is a die hard for her windows key. So perhaps i'll go with a modern G80-1800 and use that as a base to start modding it.
