Author Topic: Largest number of keys?  (Read 11491 times)
Offline bombcar
« on: Tue, 23 February 2010, 23:04:15 »
It seems that the 122 key Model F and the modern equivalent offered by Unicomp are the largest keyboards available.
Does anyone know of any beasts that are even larger? If I start journeying down the path of madness that is modernizing a Model F I want to make sure I get the most keys possible.
Offline bombcar
« Reply #1 on: Wed, 24 February 2010, 01:21:14 »
I found this 132 Key Programmable Keyboard along with its weird 176 key brother but I am suspicious.
Offline MsKeyboard
« Reply #2 on: Wed, 24 February 2010, 10:41:56 »
Quote from: bombcar;160330
This keyboard is not a good example of what you are looking for.  It is basically a programmable work station style input device.  Membrane, flat surface, slight tactile feel, and fully programmable and customizable.  Kind of like what you would see at McD's or elsewhere.
Great product if you have the need, but not for the typical user (not that everyone here is TYPICAL)
Offline bombcar
Crazy keyboard man
« Reply #3 on: Wed, 24 February 2010, 21:54:18 »
I want as many keys of wonder and glory as I can get.
I found the Avant Stellar which is in the running at  116 keys, but I think I can get higher.
Maybe I could tape two keyboards together and have one always use some modifier key or something.
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
Re: Largest number of keys?
« Reply #4 on: Wed, 24 February 2010, 22:35:06 »
At that point just use multiple keyboards and just remap everything on the other ones.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline TexasFlood
« Reply #5 on: Wed, 24 February 2010, 22:45:09 »
Quote from: bombcar;160587
It's not for me, but maybe your cup of tea:
Offline Mental Hobbit
« Reply #6 on: Wed, 24 February 2010, 23:30:36 »
The layout sucks.
Which museum is that? I need a set of Alps doubleshots.
Typing on blues.
Offline bombcar
« Reply #7 on: Wed, 24 February 2010, 23:35:50 »
I bet it's not even N-key.
Offline TexasFlood
« Reply #8 on: Wed, 24 February 2010, 23:38:30 »
Quote from: bombcar;160605
Credit card test? Need a -big- credit card.
Offline ricercar
  • mostly abides
« Reply #9 on: Thu, 25 February 2010, 01:05:22 »
Nah, not a credit card. That board would need a 4x8 sheet of plywood for the rollover test.
Offline ch_123
« Reply #10 on: Thu, 25 February 2010, 03:04:02 »
Offline HaaTa
  • Kiibohds!
« Reply #11 on: Thu, 25 February 2010, 06:05:09 »
Quote from: ch_123;160618
Hmm, now how to remap Colemak on one of those...
Kiibohd
Offline sethstorm
« Reply #13 on: Thu, 25 February 2010, 17:22:18 »
Quote from: lowpoly;160655
Tipro with 128+64=192 keys (Cherry black, Euro 49,-):
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=190360949225&ru=http%3A%2F%2Fshop.ebay.de%3A80%2F%3F_from%3DR40%26_trksid%3Dp3907.m38.l1313%26_nkw%3D190360949225%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
Question is, does it have NKRO?  It's fine and all that until you find out it only cares about 2 pressed keys at a time.
Current:
IBM: Model M: 1391401, 1386887 Terminal 122 Key
IBM: Model F: 6110668 Terminal 122 key with Trackpoint and M13 blacks
IBM: Specialty: Wheelwriter 5, Boltmodded.  AT F layout, M technology.
Lexmark/IBM: M13 Black Trackpoint
NCR:HO150-STD1-01-17 Decision Mate V - The other Gray NCR linear.
Offline ricercar
  • mostly abides
« Reply #14 on: Thu, 25 February 2010, 19:00:39 »
That's the key switch my CHPAYKEYS were designed for.
Offline mr_a500
« Reply #15 on: Fri, 26 February 2010, 12:03:31 »
Quote from: Mental Hobbit;160603
The layout sucks.
:rofl:
Offline Specter_57
« Reply #16 on: Fri, 26 February 2010, 12:47:33 »
Fentek certainly has some interesting toys...took a rather extensive look through their site finally...the left-hand keyboard, mentioned in another thread is something I'd want to play with...but I especially like the the idea of the DigiMemo Digital Writing Pads.."Digitally Capture and Store Everything You Write on Ordinary Paper"...  YEAH!!!!
and the wrist-operated roller mouse is interesting too.
spec57
« Last Edit: Fri, 26 February 2010, 12:49:59 by Specter_57 »
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #17 on: Fri, 26 February 2010, 13:52:00 »
I know what we need.
A normal 104 key keyboard.
And on the top right, a big wheel that you use to turn a big drum.
Along the top of the keyboard, a long slit through which you see a row of characters printed on the drum.
A pointer you slide along the window with a button on it to select a character.
When you do that, it's as if you typed Alt+(four digit hex number).
Type anything directly, reasonably small keyboard.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #18 on: Fri, 26 February 2010, 13:56:12 »
Quote from: quadibloc;160947
That's a ridiculously good idea.
Implementation...complex and probably costly though.
A "line" on that roll that could be custom mapped (in the keyboard controller) would be a feature to add to that concept.
kishy.ca
Offline TexasFlood
« Reply #19 on: Fri, 26 February 2010, 16:43:04 »
Quote from: ripster;160663
That Ebay one looks like it has a "SUPER SIZE ME" key. Get ready for some serious greasy keyboard cleaning.
"SUPER SIZE ME" key? WHERE?
{For itlnstln}
Offline itlnstln
« Reply #20 on: Fri, 26 February 2010, 16:44:48 »
Strong.  I like that.
That kid has no neck.
Offline ricercar
  • mostly abides
« Reply #21 on: Fri, 26 February 2010, 17:29:14 »
The heck with the keyboard cleaning. Does that boy ever wash the folds in his skin?
Quote from: Specter_57;160932
visit to Fentek is a rather expensive look...
« Last Edit: Fri, 26 February 2010, 17:31:34 by ricercar »
Offline ricercar
  • mostly abides
« Reply #22 on: Fri, 26 February 2010, 17:30:57 »
Offline msiegel
« Reply #23 on: Fri, 26 February 2010, 17:35:28 »
Quote from: kishy;160949
the drum could be emulated using a 2-line graphic lcd and a salvaged scroll wheel :)
this would make a neat hack :D
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #24 on: Fri, 26 February 2010, 17:44:03 »
Quote from: msiegel;161021
:O you're right. And it could have virtually limitless numbers of 'rows' too...not physically limited to what fits on a drum.
kishy.ca
Offline Specter_57
« Reply #25 on: Fri, 26 February 2010, 17:58:23 »
Ha...Quadi's suggestion a few posts back made me think of an Enigma machine for some reason...and also a Jefferson disk...
hmmmmm
Spec57
Offline TexasFlood
« Reply #26 on: Fri, 26 February 2010, 18:10:08 »
Quote from: Specter_57;161030
Hah, I was thinking the same thing.  Made in Germany and surely had good mechanical switches, way before Cherries though I guess.
Offline msiegel
« Reply #27 on: Fri, 26 February 2010, 18:14:03 »
sweet! :D
Offline Specter_57
« Reply #28 on: Fri, 26 February 2010, 18:23:49 »
Have you guys actually read Quadi's page, the cryptography section?
Do so for an interesting read...or a buffer overload.....
Spec57
Offline vils
« Reply #29 on: Fri, 26 February 2010, 18:34:08 »
A propos the enigma machine and cryptography. Simon Singhs The Code Book is a magnificent read.
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Offline Specter_57
« Reply #30 on: Fri, 26 February 2010, 18:39:45 »
As is The Codebreakers, by David Kahn.
Spec57
Offline bombcar
« Reply #31 on: Sun, 28 February 2010, 14:01:37 »
Well, I got a Model F dirt cheap, and a soldering iron.
Now the madness begins.
Offline lowpoly
« Reply #32 on: Mon, 01 March 2010, 13:09:30 »
Quote from: sethstorm;160727
On a POS keyboard? Not likely. I can open mine if you really need to know.
Offline sethstorm
« Reply #33 on: Tue, 02 March 2010, 11:27:09 »
Quote from: lowpoly;161367
Expecting only 2KRO, I usually go by the key-test.  Mine make it painfully obvious.
Current:
