Author Topic: Hello from Connecticut, USA  (Read 3197 times)
Offline ricrackem
« on: Fri, 26 May 2017, 10:10:30 »
Hey everyone. I've been an active reddit user for the past 5 years (/u/eizdeb) and just got into the mk community a few months ago but I'm in deep. Obviously heard a ton of stuff about GH so figured I'd check it out. Any recommendations of where I should go first? I figured I'd def check out classifieds as I'm pretty active in r/mm.
I work in the IT field at a School District and my daily driver is my HHKB. I also have a Mechmini with gat greens, a MK Disco (my first board) with KBT blues, and a tada68 with gateron reds. HHKB is bae though  :D
Not sure if imgur is what most use for image hosting here but here's my boards: http://imgur.com/a/C9G7T
Offline brianjking
  • always carry a towel.
    • @brianjking
Re: Hello from Connecticut, USA
« Reply #1 on: Tue, 06 February 2018, 16:45:59 »
Hi,
A/S/L?
haha, I had no idea your geekhack name was different from reddit.
Offline ZayaCaps
    • Instagram
« Reply #2 on: Tue, 06 February 2018, 21:09:32 »
Welcome to GH!
Based on your listed interests, I recommend checking out the classifieds as well the group buys to stay up-to-date on new sales. I also recommend checking about the meetup section as there are several meetups in New England, usually in Massachusetts, that would be great for showing off those awesome boards. ;)
