Author Topic: [SOLVED] GH60 Programming # programmed instead of \  (Read 1290 times)
Offline aholland909
« on: Sun, 28 May 2017, 16:29:58 »
Greetings
I've tried to program my GH60 using EasyAVR, all other keys were fine apart from the backslash and pipe key, which when programmed produces a # and ~.
I think is a issue with the AVR 'HID_KEYBOARD_SC_BACKSLASH_AND_PIPE', because the key being programmed can be programmed to others.
Thanks
EDIT : I just needed to change 'HID_KEYBOARD_SC_BACKSLASH_AND_PIPE' to 'HID_KEYBOARD_SC_NON_US_BACKSLASH_AND_PIPE'
« Last Edit: Sun, 28 May 2017, 16:54:23 by aholland909 »
