Author Topic: solved  (Read 1237 times)
Offline Encabulator
solved
« on: Wed, 31 May 2017, 09:33:24 »
dumb question
« Last Edit: Wed, 31 May 2017, 09:40:06 by Encabulator »
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Offline Tactile
Re: Best PCBs with pre-soldered components?
« Reply #1 on: Wed, 31 May 2017, 09:41:22 »
Just about any PCB you find will have the small components pre-soldered, requiring only switches. Just find one you like the looks of and you can link it here to have people check & make sure.
What size keyboard are you thinking of?
REΛLFORCE
