Author Topic: Which LED lighting is better... through holes or surface mounted?  (Read 4043 times)
Offline dman777
Which RGB LED keyboards give the best lighting... the ones where the lights are surface mounted or the ones that shine through PCB holes?
Offline SpectreiiI
  • Scribe
Re: Which LED lighting is better... through holes or surface mounted?
« Reply #1 on: Thu, 01 June 2017, 23:12:06 »
I have no idea what you are asking.
Offline Parva Ovis
« Reply #2 on: Thu, 01 June 2017, 23:16:41 »
I've casually compared an SMD RGB keyboard with a single-color through-hole LED keyboard and the backlighting seemed close to equal in both, but I've never seen an RGB through-hole keyboard for true comparison.
Offline Eszett
« Reply #3 on: Thu, 01 June 2017, 23:20:16 »
LEDs that shine through PCB holes are surface mount too
Offline dman777
« Reply #4 on: Fri, 02 June 2017, 15:19:21 »
That is what I was thinking also... but reviews imply  that LED shine through PCB holes, like Ducky, give better light so I was wondering why/how.
Offline Tactile
« Reply #5 on: Fri, 02 June 2017, 15:35:10 »
I have a Ducky One RGB. The LEDs shine up through the holes in the PCB into the - and here's the key - clear housings of the Cherry RGB switches. Most of the light shines through just where you'd expect but the entire housing picks up some of the light & glows a bit also, so there's a little more spread to the light. It just makes the lighting a bit more even front-to-back and on the sides.
REΛLFORCE
