Author Topic: Do Costar 2U stabalisers fit 1.75U key caps?  (Read 2147 times)
Offline M4R5
« on: Sat, 03 June 2017, 04:18:08 »
They seem to be too wide, but 1.75U bars don't seem to be generally available.
Offline TalkingTree
    • My projects
Re: Do Costar 2U stabalisers fit 1.75U key caps?
« Reply #1 on: Sat, 03 June 2017, 04:57:35 »
Theoretically, you can do without the stabilizer for a 1.75u key.
Offline M4R5
« Reply #2 on: Sat, 03 June 2017, 06:30:01 »
Yes but I think using a stabiliser is better for 1.75U
Offline TalkingTree
    • My projects
« Reply #3 on: Sat, 03 June 2017, 07:07:27 »
I assume your keycap has stems for stabilizers, in that case you could bend your own wire for the purpose.
