Author Topic: Banana Split 60 build questions  (Read 2717 times)
Offline Robsonj
« on: Sun, 04 June 2017, 15:10:31 »
Hi there,
Appologies if this is posted in the wrong place.
I was wondering if for the Banana Split 60 keyboard, Zealios 65g plate mounted switches would work for the banana split plate & pcb combo.
I'm pretty sure they will be fine, but wanted to double check as this will be my first custom build.
Cheers
Jonathan
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
Re: Banana Split 60 build questions
« Reply #1 on: Mon, 05 June 2017, 00:46:09 »
Yes, they should work :)
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
Offline Robsonj
« Reply #2 on: Mon, 05 June 2017, 07:13:43 »
Thank you!
