Author Topic: HyperFuse Redux  (Read 157547 times)
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
HyperFuse Redux
« on: Thu, 08 June 2017, 16:28:53 »
In stock! Will go live tomorrow.
https://originative.co/products/hyperfuse-redux
Offline LoLPirate
Re: HyperFuse Redux
« Reply #1 on: Thu, 08 June 2017, 16:32:03 »
So are the alphas more or less white m
Sent from my Pixel using Tapatalk
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: HyperFuse Redux
« Reply #2 on: Thu, 08 June 2017, 16:32:29 »
same alphas, different grey for the mods
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: HyperFuse Redux
« Reply #3 on: Thu, 08 June 2017, 16:40:16 »
You're actually posting on GEEKHACK now :)
You're coming to the LA MEET, right? I just booked the Taco Cart today.
Offline poolside
Re: HyperFuse Redux
« Reply #4 on: Thu, 08 June 2017, 16:42:57 »
How many keycaps does the set include?
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: HyperFuse Redux
« Reply #5 on: Thu, 08 June 2017, 16:47:36 »
144
extra barred f/j
shift
75%
1800 layout
iso uk
winkeyless
hhkb
extra 2 accent keys
Offline poolside
Re: HyperFuse Redux
« Reply #6 on: Thu, 08 June 2017, 17:20:25 »
144
extra barred f/j
shift
75%
1800 layout
iso uk
winkeyless
hhkb
extra 2 accent keys
Thanks. I assume that shift is an extra 2.25 one?
Will this set have the R1 tilde/backtick which was missing from the previous HF rounds?
Cyan or purple accents?
Some Code/Diamond alternative for Win keys?
Otherwise, it looks like the navigation cluster above the arrow keys has now icons.
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: HyperFuse Redux
« Reply #7 on: Thu, 08 June 2017, 17:21:51 »
144
extra barred f/j
shift
75%
1800 layout
iso uk
winkeyless
hhkb
extra 2 accent keys
yes, extra 2.25u shift
extra ~ and \| for both colors.
Windows only
Cyan on Purple is available in HyperFuse Accent Kit
Icons for above nav cluster but the 75/1800 is still text
Offline LoLPirate
Re: HyperFuse Redux
« Reply #8 on: Thu, 08 June 2017, 17:40:44 »
I'll post every so often. And yes I will be there. Bb I told you this. If you host, my body will be there.
Offline autobot
Re: HyperFuse Redux
« Reply #9 on: Thu, 08 June 2017, 19:42:43 »
Will regular Hyperfuse be restocked?
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: HyperFuse Redux
« Reply #10 on: Thu, 08 June 2017, 19:56:36 »
Not soon
Offline mindxthinker
Re: HyperFuse Redux
« Reply #11 on: Fri, 09 June 2017, 00:02:50 »
« Last Edit: Fri, 09 June 2017, 07:55:06 by mindxthinker »
Offline evd198111
Re: HyperFuse Redux
« Reply #12 on: Fri, 09 June 2017, 00:59:26 »
Do you have a countdown for this? Dont want to miss out on this or be to late to order.
Offline Jedi
Re: HyperFuse Redux
« Reply #13 on: Fri, 09 June 2017, 05:10:00 »
Looks to be live now...
Offline oatmicro
Re: HyperFuse Redux
« Reply #14 on: Fri, 09 June 2017, 10:21:58 »
Damn, I just paid for Ruri recently and this beauty show up.
It would be great if they are still in the stock until the end of this month.
Also if I can get something like "Almost out of stock" will save me a lot but I can't   :(
Offline ATXTider
  • I keep it playa while some choose to play it safe
Re: HyperFuse Redux
« Reply #15 on: Fri, 09 June 2017, 10:34:31 »
What was the reason for the mod color change?  To make it easier on the eyes?
Offline autobot
Re: HyperFuse Redux
« Reply #16 on: Fri, 09 June 2017, 11:51:26 »
Just ordered a set!
...and I'll probably get regular Hyperfuse when that comes in. Sherry, you're killing me!  :))
I mocked up this set with the silver R2 Norbauer case, Hyperfuse Window Accents (from Hyperfuse accent kit) stainless steel USB cable, and Windows & alt swapped positions for Mac OS. I currently have a CM Masterkeys S MX Browns, I might replace with a MX Blues version. This is seriously approaching endgame territory for me!
Offline Petch
Re: HyperFuse Redux
« Reply #17 on: Fri, 09 June 2017, 13:25:51 »
Do these have the same issue Honeywell did?
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: HyperFuse Redux
« Reply #18 on: Fri, 09 June 2017, 13:32:55 »
We're trying to keep sets unique as much as possible. These colors were something that we always wanted to do at Originative. This is a much more proper collaboration in our own opinion.
Just ordered a set!
This Mock Up actually represents the color really well. Your thoughts?
So far with the sets we have opened, we don't have any issues.
Offline autobot
Re: HyperFuse Redux
« Reply #19 on: Fri, 09 June 2017, 14:26:35 »
Very nice, I think the softer mods gray would match very nicely with the aluminum. It gives the set a dreamy feel with the powdery gray. I am a little concerned with contrast legibility on the mods, but I'll see how that comes off when I receive the set.
Also the icon mods look fresh, as I think the text + icons look are starting to look dated to me.
I noticed this when looking at kekkon's Dolch Reborn vs Sky Dolch (still a gorgeous set, as I'm currently rocking that with Miami accents and Magenta mods
 :thumb:)
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: HyperFuse Redux
« Reply #20 on: Fri, 09 June 2017, 14:27:53 »
 :thumb:)
That's how I felt at first. You can look at our new banner picture to get a better feel of the contrast. The Cyan is definitely vibrant. This is what people were scared of when Sky Dolch came out, but it's the samething almost.
I just want you to make sure that the 75/1800 keys aren't textless.
Offline autobot
Re: HyperFuse Redux
« Reply #21 on: Fri, 09 June 2017, 15:22:36 »
Yep, I figured that since that was the case for Miami/Miami Nights.  ;)
Perhaps posting the GMK Render of the complete set, or at least a photograph of the set in the tray would help clarify to those who might not know?
The photos help convey what they look like in real life (as the GMK renders are always very off), but the GMK Renders do help in that they very clearly show what keys are included.
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: HyperFuse Redux
« Reply #22 on: Fri, 09 June 2017, 15:25:45 »
The best referral link right now is this: http://imgur.com/a/cPYjD
Bad representation of the set and the keys above the nav cluster are icons.
Offline evd198111
Re: HyperFuse Redux
« Reply #23 on: Fri, 09 June 2017, 15:48:30 »
realy love the lighter gray colour. Have placed an order, will you start shipping these next week?
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: HyperFuse Redux
« Reply #24 on: Fri, 09 June 2017, 15:57:02 »
already started shipping unless you ordered it with something that is pre-order/back-order/or in group buy.
Offline poolside
Re: HyperFuse Redux
« Reply #25 on: Fri, 09 June 2017, 16:55:47 »
1.25u CapsLock, nice :thumb:
Offline robotsokk
Re: HyperFuse Redux
« Reply #26 on: Fri, 09 June 2017, 20:34:36 »
The other day on originative.co, I noticed that the Hyperfuse listing included a "Coming Soon" notice, so I've been watching... Lucky me that "soon" turned out to be a matter of days. :)
I went ahead and went in for this. While I'm personally a fan of the text mods over the icon mods, it's still a nice, clean look (and I'm a fan of the general colorway since seeing pics from the original run). I'm going to experiment with mixing in the accent kit and my Sky Dolch mods; I'm betting it'll look great.
@home      @work Swapping out boards... coming soon     wtb
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: HyperFuse Redux
« Reply #27 on: Fri, 09 June 2017, 20:48:01 »
sounds great. you'll be surprised how good the redux is.
Offline Petch
Re: HyperFuse Redux
« Reply #28 on: Sat, 10 June 2017, 17:24:57 »
Do you have a picture of the full set?
Offline MMKB
Re: HyperFuse Redux
« Reply #29 on: Fri, 16 June 2017, 00:15:03 »
Offline autobot
Re: HyperFuse Redux
« Reply #30 on: Fri, 16 June 2017, 10:13:57 »
Gorgeous! My set is out for delivery today!
Offline euphxenos
Re: HyperFuse Redux
« Reply #31 on: Fri, 16 June 2017, 16:23:23 »
Does this set include the R3 PgUp and R4 PgDn needed for the default layout of your Saber keyboard?
Offline robotsokk
Re: HyperFuse Redux
« Reply #32 on: Sat, 17 June 2017, 04:48:02 »
Got mine (Hyperfuse Redux + HF accent kit) Friday :D Warning, potato pics below...
Gotta say, I was feeling iffy on the icon mods, but I really like them in person. And the lighter grey works. Really pleased to finally have my hands on Hyperfuse.
Offline mtzgr
    • My youtube
Re: HyperFuse Redux
« Reply #33 on: Sat, 17 June 2017, 16:09:45 »
Ordered a set and it looks good. The lighter mods are more subtle. The legends don't contrast as well with the lighter gray, but I think it contrasts better with the set (and they are still sharp enough).
Fn came scratched which is a shame because I wanted to use it. The tray works well but the little addon trays GMK uses are awful. Every set I receive the keys shift around on top of each other and get ****ed up. Should just ship them in a bag.
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: HyperFuse Redux
« Reply #34 on: Tue, 20 June 2017, 16:25:00 »
It looks good!
Make sure to email us the information. We'll give the details to GMK.
Offline potatobbq
Re: HyperFuse Redux
« Reply #35 on: Mon, 10 July 2017, 04:31:54 »
Anyone with barred F/J keys that they want to sell? :D I already have the original set but really really prefer barred over scooped so I'm about to buy the entire Redux set essentially for 2 keys, lol
Offline xondat
  • i'm not a star
Re: HyperFuse Redux
« Reply #36 on: Mon, 10 July 2017, 04:49:50 »
Offline Giorgio
Re: HyperFuse Redux
« Reply #37 on: Mon, 10 July 2017, 04:56:33 »
+1$ :-)
Offline energyd
Re: HyperFuse Redux
« Reply #38 on: Fri, 18 August 2017, 14:26:11 »
Where do I get the Hyperfuse Accent Kit?
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
Re: HyperFuse Redux
« Reply #39 on: Fri, 18 August 2017, 14:33:57 »
It can sometimes be bought from Originative however it's not in stock at the moment
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: HyperFuse Redux
« Reply #40 on: Thu, 12 October 2017, 13:27:46 »
HyperFuse Accent Kit will be back up shortly :)
Offline poolside
Re: HyperFuse Redux
« Reply #41 on: Thu, 12 October 2017, 14:28:24 »
Now that GMK Red Honey and Red Honey Cyrillic have their R2 1u Delete keycap with the arrow icon pointing in the correct direction (to the right), could GMK HF Redux get a little fix kit including that cap? An "extended" fix kit could also include the missing 1800 caps with icon legends.
Offline PoisonKing
  • RIP wallet
Re: HyperFuse Redux
« Reply #42 on: Thu, 12 October 2017, 21:20:53 »
Including the non-Redux version pleaseeeee :)
Offline energyd
Re: HyperFuse Redux
« Reply #43 on: Fri, 13 October 2017, 16:44:37 »
Thanks, will it be any notification when it's available?
Offline autobot
Re: HyperFuse Redux
« Reply #44 on: Sun, 15 October 2017, 15:47:45 »
This along with missing icon mods, icon esc (gray & accented), 00, and windowed/stepped windowed caps lock, and accent numpad enter. I'd buy it in a heartbeat.
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: HyperFuse Redux
« Reply #45 on: Sun, 15 October 2017, 17:36:22 »
We will post them in the Newsletter!
Offline oatmicro
Re: HyperFuse Redux
« Reply #46 on: Mon, 16 October 2017, 07:15:24 »
Redux version or Normal version?  :-[
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: HyperFuse Redux
« Reply #47 on: Mon, 16 October 2017, 15:06:24 »
Pretty much both since it's just the colored keycaps.
Offline amnesia0287
  • Formerly Amnesia
Re: HyperFuse Redux
« Reply #48 on: Tue, 17 October 2017, 00:31:46 »
Is this just really contrasty, or did you run darker hyperfuse with icons?
Offline autobot
Re: HyperFuse Redux
« Reply #49 on: Tue, 17 October 2017, 09:22:40 »
Depends on the lighting, that picture in my mind exaggerates the contrast quite a bit, while Originative's photos reduce the contrast a hair.
Also, having Ocean Dolch (same color mods as OG Hyperfuse), the Redux mods aren't really lighter than OG mods, but are cooler. I think the Redux mods play a bit nicer with the cool silver color that clear anodized aluminum has. Also, it was a good move on Sherry's part to go with icons vs text, as the icons seem easier to read in TU2 on this new gray than had it been text.
It's quite a beautiful set in person, and pairs excellently with silver aluminum.
Here's a photo of my set:
