Author Topic: searching a compact keyboard  (Read 1633 times)
Offline dragonload
« on: Fri, 09 June 2017, 05:29:14 »
does someone know a decent keyboard with close function keys? for example like noppoo choc mini.
« Last Edit: Fri, 09 June 2017, 10:37:17 by dragonload »
Offline Tactile
Re: searching a compact keyboard
« Reply #1 on: Fri, 09 June 2017, 12:09:15 »
If you search for a "75% keyboard" I think you might find something you like.
REΛLFORCE
Offline ideus
  • Björkö.
« Reply #2 on: Fri, 09 June 2017, 12:44:51 »
+1, as far as I know the choco is the only keyboard in that size with FN keys.
Offline dragonload
« Reply #3 on: Fri, 09 June 2017, 13:23:06 »
hey, thanks for answering.
i'm actually talking about the f-keys on the top. so they have to be close together, like on a laptop keyboard - that's what i mean with compact.
it doesn't have to be a 75%, tkl or mechanical keyboard.
example: razer everglide
