Author Topic: [GB] UK78 - 60%+Numpad [Completed] *UPDATE* PCBs and R2 plan  (Read 285734 times)
Offline FearsomeCubedWarrior
  •  Post Reporting Timeout
Re: [GB] UK78 - 60%+Numpad - 100% Shipped
« Reply #450 on: Wed, 15 November 2017, 13:45:54 »
« Last Edit: Mon, 15 April 2024, 18:47:16 by FearsomeCubedWarrior »
Offline shadowrealmwarez
« Reply #451 on: Wed, 15 November 2017, 13:53:53 »
Ok. it looks like for some reason I've lost RGB at all.
It worked initially prior soldering, but after I've soldered in-switch leds (which are VERY dim after installation, although they are actually very bright when connected to USB directly) the RGB is just gone.
There're some other strange things like backlight level almost not working on that LED or toggle LED working when they're set to minimum level.
Of course I've tried to flash default FW with no luck.
I've used this leds.
So, did I burn something, or that's software issue? Can I troubeshoot that someway?
When you say "USB directly" are you using a USB hub vs plugging directly into a USB port?
« Reply #452 on: Thu, 16 November 2017, 12:01:04 »
« Last Edit: Mon, 15 April 2024, 18:47:22 by FearsomeCubedWarrior »
Offline rozakiin
  • British Custom Anyone?
    • UK Keyboards
« Reply #453 on: Thu, 16 November 2017, 12:07:28 »
Sorry, not directly. Plugged into breadboard powered up with adapter from USB. Anyway, voltage was set to 3.3 volts and LED was that bright:
And installed to PCB it was that dim:
Moreover, with RGB activated, in-switch LEDs just turn off.
Now a bit about RGB. I've turned it off accidentally (set brightness to minimum level) cause actual keymap binding and that shown in keymap.c as an illustration differs. Whatever, I've identified the keys to tune RGB and set it on. But again, for some reason, it took quite some time for keyboard to initialize (3-4 seconds) and it hanged after playing with RGB settings after some time. The only solution was to unplug it and plug back again.
After another unplug the PCB seems dead: Flip doesn't recognize chip, no new devices in device manager after KB is plugged in, no initial flash of all LEDs after KB is plugged in. I can only guess that I've burned the chip with that LEDs. Well, now I've got an expensive brick.
I can give a reason for the LEDs appearing to turn off with the RGB, this is due to the amount of current supplied by the USB, there isn't enough current to drive the LEDs and RGB at once so the LEDs get very dim. Could also be the reason why the LEDs were brighter when attached to an adaptor.
« Reply #454 on: Thu, 16 November 2017, 12:19:10 »
« Last Edit: Mon, 15 April 2024, 18:47:28 by FearsomeCubedWarrior »
Offline rozakiin
    • UK Keyboards
« Reply #455 on: Thu, 16 November 2017, 12:51:42 »
Yeah, my thoughts exactly.
And most likely the reason for PCB becoming brick is the same: simultaneous RGB and in switch LEDs ultimately killing something with overcurrent.
Now upon plugging it some random RGB led just flashes briefly and that's it.
Any way to fix it, or I can just trash entire thing?
If it "died" while connected through USB then it should be fixable, the pcb has a resetable fuse for over current protection. Is anything detected by the pc when plugged in?
« Reply #456 on: Thu, 16 November 2017, 13:33:47 »
« Last Edit: Mon, 15 April 2024, 18:47:35 by FearsomeCubedWarrior »
Offline rozakiin
    • UK Keyboards
« Reply #457 on: Fri, 17 November 2017, 03:27:44 »
Nope, nothing is detected at all. Tried several times, holding reset as well -- no new devices.
Could be that the bootloader got messed up, you could try and reflash the chip via isp. If you PM me I could try and help you through the steps.
Offline Delirious
« Reply #458 on: Fri, 24 November 2017, 14:10:22 »
Finally built mine.
- SKCM Browns (thanks to E3E for the hookup)
- ABS plate
- Taihao Arabic caps
Offline ectoplasmatic
« Reply #459 on: Fri, 24 November 2017, 15:59:37 »
Woooo good job that is really fresh. Wow. Mixture of alps, abs plate... and then that modern case are just “ooof”. I’ve never seen an abs plate before how is it compared to acrylic?
Offline Delirious
« Reply #460 on: Fri, 24 November 2017, 18:20:23 »
ABS plate is much softer and flexy than acrylic. ABS is also much more durable than acrylic, you have to really want to damage ABS plate before you see any crack; on the other hands acrylic cracks easily even when you just tighten the screws. Comparing between acrylic, abs, and polycarb; I would rate them:
Hardness:
10 - Acrylic
3 - ABS
1 - Polycarb
Durability/Brittleness:
10 - Polycarb
7- ABS
2 - Acrylic
I highly recommend abs plate over acrylic and polycarb. Acrylic plate is crackable easily while polycarb is difficult to machine. Here're the flex comparisons between polycarb(white) vs abs(black)
Offline MMKB
« Reply #461 on: Fri, 24 November 2017, 22:23:36 »
Finally built mine.
- ABS plate
Just beautiful. Dig the last shot. If you could share the typing sound on the abs plate that would be awesome.
« Reply #462 on: Sun, 26 November 2017, 12:48:00 »
Hardness:
10 - Acrylic
3 - ABS
1 - Polycarb
10 - Polycarb
7- ABS
2 - Acrylic
Hey thanks so much for that, really informative!
Offline forumusername
« Reply #463 on: Fri, 15 December 2017, 22:21:37 »
Hardness:
10 - Acrylic
3 - ABS
1 - Polycarb
10 - Polycarb
7- ABS
2 - Acrylic
that looks fantastic!  do you have any more abs plates? thanks for sharing the build
Offline Traveler
« Reply #464 on: Sun, 17 December 2017, 20:37:34 »
Alright, so I have what is likely a dumb question. I'm just now getting around to putting my board together, and I noticed on the PCB that the backslash/pipe key for ANSI layout has a stabilizer cutout right where a pin of my switch would go. I did some crude circling on a photo below; red is the spot in question and green is a "normal" set of pin holes.
So how do I solder this? Just use more solder than a normal pin?
Offline rozakiin
    • UK Keyboards
« Reply #465 on: Mon, 18 December 2017, 16:52:34 »
Hi, yes you just need to add slightly more solder to bridge the connection.
Offline Delirious
« Reply #466 on: Mon, 18 December 2017, 17:52:06 »
Hardness:
10 - Acrylic
3 - ABS
1 - Polycarb
10 - Polycarb
7- ABS
2 - Acrylic
I have my unbuilt LZ waiting for the pcb.
« Reply #467 on: Thu, 21 December 2017, 17:51:20 »
I'll take that as "no I don't have anymore for the UK78 if you wanted to buy one' :thumb:
« Reply #468 on: Mon, 26 February 2018, 12:27:02 »
I'm a little late to the party but I finally built thanks again Roz!
https://imgur.com/a/OOBk7
Sent from my Nexus 6P using Tapatalk
Offline xondat
  • i'm not a star
« Reply #469 on: Mon, 26 February 2018, 12:29:06 »
Looks great noob.
« Reply #470 on: Mon, 26 February 2018, 14:14:32 »
« Last Edit: Mon, 15 April 2024, 19:01:45 by FearsomeCubedWarrior »
Offline Traveler
« Reply #471 on: Mon, 26 February 2018, 17:08:53 »
Niiice. Makes me wish mine wasn't bricked. I enjoyed it the ten minutes I got to use it. I was going to attempt desoldering it yesterday so I could get to the ISP connectors but I quickly learned that I totally suck at desoldering. YouTube vids make the solder sucker look so easy but boy does it not work for me.
I'm gonna pick up something like the Tenma 21-8240 in hopes that it'll work better for me. If not I'm screwed. Not sure if it would be better to get someone on r/mechmarket to desolder it for me or for me to buy a whole new PCB and switches.
« Reply #472 on: Mon, 26 February 2018, 17:40:30 »
« Last Edit: Mon, 15 April 2024, 19:01:51 by FearsomeCubedWarrior »
Offline Traveler
« Reply #473 on: Mon, 26 February 2018, 18:12:39 »
What happened to yours?
I've got mine bricked as well, I assume by using both underglow and in-switch LEDs.
I guess I should have said "soft bricked". The keyboard is usually detected when it's in DFU mode. When I try to flash I get an error about the memory not being blank at 0x1. I believe the culprit was a corrupted .hex. All of my problems happened immediately after I tried to flash a new one.
Funny enough I have some in-switch LEDs too. I don't think they're my problem but I won't be including them again the next time I put my board together.
« Reply #474 on: Mon, 26 February 2018, 18:14:20 »
I have a desolder gun pm me if you need some help or suggestions on better tools.
Thank you for the kind words cheers
Offline ojrask
  • juuh elikkäs
« Reply #475 on: Tue, 27 February 2018, 05:05:18 »
My UK78 has become my favorite board so far. Maybe R2 at some point so I can get a black one for work? ;)
Current:
Coming up:
IC/GB:
« Reply #476 on: Tue, 27 February 2018, 13:24:37 »
In for round 2!
Offline speaktobrett
« Reply #477 on: Tue, 27 February 2018, 17:57:54 »
In for round 2!
Me too! Please bring out the Round 2 of UK78 !!
Offline Peppermint216
« Reply #478 on: Tue, 06 March 2018, 06:21:01 »
Any interest in a 5mm frosted diffuser/base?
Offline Traveler
« Reply #479 on: Tue, 06 March 2018, 07:00:41 »
I know I'd be interested in a diffused bottom piece. I've thought about picking some acrylic up and sanding it myself, but I've never done anything with acrylic so idk how it will turn out.
« Reply #480 on: Tue, 06 March 2018, 07:04:34 »
I would rather have it done professionally and that means it would have to be laser cut due to CNCs cutting tolerance of 1mm.
I want one so if I can get a few people to do it with me the price will go down.
Also it being 5mm it is thicker that the 3mm it came with so would also need some extra screws I could provide.
Offline Traveler
« Reply #481 on: Tue, 06 March 2018, 12:18:48 »
Gotcha. Well you can count me in if the price is right. There's a list of the people who purchased one in the post at the beginning of this thread; not sure if it would be rude or not to PM them all and ask if they're interested. I know it would be the most straightforward way to get more people on board.
« Reply #482 on: Wed, 07 March 2018, 15:56:39 »
Decided to do some experimenting seen as I had a spare diffuser.
The first image below shows a sanded edge diffuser with 1.7mm washers above it, simulating a 4.7mm piece of acrylic. The second image shows the original 3mm diffuser without sanded edges with the exact same underglow settings.
Offline clickstops
« Reply #483 on: Fri, 16 March 2018, 14:23:52 »
Wow, that looks far better than I would've anticipated! Looks excellent.
« Reply #484 on: Fri, 16 March 2018, 14:32:26 »
I actually got 6 panels delivered today, they are cut perfectly. Unfortunately they are gloss white and I asked for frost white so these are no good, I have asked for them to be replaced.
I ordered 3 full base pieces, with 4 screw holes and 3 small feet pieces with 8 screw holes.
If there is no problem with the replacement they should be 4GBP + Postage.
5mm gloss white image below.
Offline SBN
« Reply #485 on: Sat, 17 March 2018, 05:09:47 »
Really appreciate your work! I like to see people adding stuff like this after the GB :)
So I would like one panel! Should I pm you or will you post further details here?
« Reply #486 on: Sat, 17 March 2018, 05:12:09 »
If anyone wants one pm me what type you need because right now I'm thinking 3 full base and 3 small feet types.
« Reply #487 on: Fri, 23 March 2018, 07:42:32 »
Replacements have been shipped, arriving next week.
« Reply #488 on: Sat, 24 March 2018, 13:15:00 »
I wish I had opted for a full base instead of just acrylic one... if anyone wants to sell me one let me know  :thumb:
Also finally built my second kit.  I'm ready for round 2 Roz  :D
https://imgur.com/a/8dfK2#rQI6MoY
« Reply #489 on: Mon, 26 March 2018, 15:04:32 »
Plates arrived! 3 reserved, 2 left.
« Last Edit: Mon, 26 March 2018, 15:09:08 by Peppermint216 »
« Reply #490 on: Mon, 26 March 2018, 15:05:54 »
Why are my images published upside down  :confused:
Offline KaosJ
« Reply #491 on: Mon, 26 March 2018, 15:06:52 »
What you got left exactly and where are you from? From pics seems like you are in Australia :/
« Reply #492 on: Mon, 26 March 2018, 15:08:44 »
 :)) Really dunno why it's done that, sorry. I am in the UK. 2 full bases left (only 4 holes in each corner).
« Reply #493 on: Mon, 26 March 2018, 15:11:02 »
I also have 6 Gloss white ones, they do diffuse but the leds have to be on full brightness to fill the acrylic.
2 Full base frosted left.
Offline KaosJ
« Reply #494 on: Mon, 26 March 2018, 15:12:25 »
I wasn't in for the GB, i can't get any leftover i guess?
« Reply #495 on: Mon, 26 March 2018, 15:14:38 »
UK78's? You would have to check r/mm.
Offline KaosJ
« Reply #496 on: Mon, 26 March 2018, 15:26:06 »
Ye RIP me :(
Offline Traveler
« Reply #497 on: Mon, 26 March 2018, 16:03:57 »
Mind sharing one last pic of the bottom/flat side of the plate itself? Curious as to how much it's actually frosted. These look great though; definitely interested in fulfilling my reservation.
« Reply #498 on: Mon, 26 March 2018, 16:34:55 »
I had to go with a frosted white, frosted clear has completely clear edges. Also compared to the original gloss white I got below.
Offline Traveler
« Reply #499 on: Mon, 26 March 2018, 18:27:05 »
Looks good to me. I'll PM you my info.
