Author Topic: Question On Current Massdrop PBT keycaps  (Read 3464 times)
Offline dman777
« on: Sat, 10 June 2017, 15:19:32 »
https://www.massdrop.com/buy/blank-pbt-keycaps?mode=guest_open&utm_campaign=Drop%3A%20FOMO%20%28New%29&utm_source=SparkPost&utm_medium=email&utm_term=Drop%3A%20FOMO%20%28New%29&utm_content=1497121577622.973706387279948722693448&referer=ZUPW9Z
Does anyone know if:
1) These are double shot PBT key caps?
2) Is the lettering see through for color ids?
3) How well the LEDS will glow through the keycaps?
3) Is this colored plastic or painted?
4) Would led's shine through as the plastic and lettering as good as the image I attached?
Offline Tactile
Re: Question On Current Massdrop PBT keycaps
« Reply #1 on: Sat, 10 June 2017, 15:26:11 »
The set you have linked to are blank. Is there another set you meant to ask about?
REΛLFORCE
Offline dman777
« Reply #2 on: Sat, 10 June 2017, 15:29:16 »
No, there is a option for the set to have letters when I buy them...I think... 'You'll also have the option to add an ISO-compatibility pack containing R3 1u, R4 1.25u, R4 1u, and large Enter (+ $3)'
Offline Tactile
« Reply #3 on: Sat, 10 June 2017, 15:33:07 »
That add-on pack just contains additional cap sizes for an ISO keyboard. The keycaps are all blank.
REΛLFORCE
Offline Vladimir
  • Professional Dream Crusher
« Reply #4 on: Sat, 10 June 2017, 15:34:43 »
No, this Group Buy is for Blanks only.
The one with legends finished a few days ago:
https://www.massdrop.com/buy/133-key-pbt-cherry-keycap-set
EDIT: Which btw, were laser etched.
« Last Edit: Sat, 10 June 2017, 15:37:23 by Vladimir »
 Matias Mini Quiet Pro              Noppoo Nano 75-S Brown
Offline dman777
« Reply #5 on: Sun, 11 June 2017, 14:10:11 »
I can't believe I missed that one. Is laser etched bad or good? I am hoping for led to shine through.
Offline f32h80fsd08h34r5
« Reply #6 on: Sun, 11 June 2017, 15:11:26 »
You're not going to get good shine through with laser etched + PBT.
