Author Topic: Keycult (keyboards etc.)  (Read 212188 times)
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« on: Wed, 14 June 2017, 11:38:18 »
https://www.keycult.io
Original post:
Hi geekhack friends,
I've been quietly working on this project over the last 6 months. I now have a working prototype and a small initial run is in the works, so I thought it would be a good time to share a bit more. This is my first keyboard design, my first time using CAD software, and my first time having something I created manufactured. Since these are plenty of firsts, and since I don't care overly much about naming, I'm happy to introduce the No. 1, a custom TKL.
There are three design decisions I'd like to mention. The first is that the "weight" isn't so much of a weight as it is half of a two-part case bottom — the weight design visible on the underside of the case is the same piece of material that forms the strip that runs around the side and back of the case. The second is that the plate is sandwich-mounted between the two-part bottom and the case top. Sandwich-style cases have, in my experience, provided the best typing experience and sound compared to bottom or top-mounted plates. Third, adhesive rubber gaskets have been incorporated into grooves in the case top to ensure that the plate is sandwiched perfectly with no wiggle room.
I'm currently running a small, private group buy for a small order of these, but I'm working with a vendor to make a larger quantity available to folks down the line. Thanks for checking it out. =)
Update 2017/8/10: Some boards from the first production run:
Update 2017/9/4: Keycult No. 1 Build Log
Update 2017/10/26: Keycult No. 1 Companion Wrist Rest
« Last Edit: Fri, 06 July 2018, 22:09:23 by riotonthebay »
Re: No. 1 – Custom TKL (prototype & renders inside)
« Reply #1 on: Wed, 14 June 2017, 11:40:10 »
lol Will the next one be called No. 2?
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #2 on: Wed, 14 June 2017, 11:40:34 »
 Yee
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #3 on: Wed, 14 June 2017, 11:41:45 »
Hot Diggity
Dewd
That **** is fire
  • Cherry Peasant
  • keycult.com
« Reply #4 on: Wed, 14 June 2017, 11:44:00 »
Yes, and it will only come in brown
Offline kiwi99
  • that's a gnarly dookie
« Reply #5 on: Wed, 14 June 2017, 11:50:40 »
Interesting route to take with the bottom weight/tray, it separates it from other TKLs in a unique way which is great. :) GL with this
Offline laughatpain
« Reply #6 on: Wed, 14 June 2017, 11:53:55 »
He was no.1
Offline roostrc0gburn
  • its just plastic
« Reply #7 on: Wed, 14 June 2017, 11:58:41 »
holy cow, that is an amazing effort for your first design!
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #8 on: Wed, 14 June 2017, 12:04:20 »
The finish on that case is flippin' beautiful
Offline SixtyLife
« Reply #9 on: Wed, 14 June 2017, 13:15:15 »
that looks so good, great work man. any shots of the whole board?
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline byker
  • Literally Canada
« Reply #10 on: Wed, 14 June 2017, 13:16:54 »
Looking good my man
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #11 on: Wed, 14 June 2017, 15:23:49 »
That looks really good.
I like the design of the diffuser - that looks like it's going to do a great job getting the RGB LED's on the bottom of the PCB to evenly illuminate the edges.  What PCB did you choose?
    • WTB/WTTF Thread
« Reply #12 on: Wed, 14 June 2017, 15:59:54 »
It's not a diffuser. Thats a solid piece of metal
« Reply #13 on: Wed, 14 June 2017, 16:08:01 »
HhhHHHEEeelllLLL YYyeeAAAhH
Offline xondat
  • i'm not a star
« Reply #14 on: Wed, 14 June 2017, 16:41:37 »
Obviously a massive fan. Maybe No. 2 will be mine.
Offline Weiss
  • Impulse buying at its finest
« Reply #15 on: Wed, 14 June 2017, 16:52:18 »
Wow looks really nice.
Definitely gonna be on the lookout for a group buy when it goes public!
Offline MajorKoos
« Reply #16 on: Wed, 14 June 2017, 16:58:11 »
It reminds me of the VE.A.
It has something similar going with the polycarb inner shell.
Offline ppp
  • KappaKeepoKoopa
« Reply #17 on: Wed, 14 June 2017, 18:42:22 »
awesome job!
gib pls
Offline Jokrik
« Reply #18 on: Wed, 14 June 2017, 18:45:38 »
Offline Fictiouz
  • That "White" Guy
« Reply #19 on: Wed, 14 June 2017, 19:42:42 »
I am a full supporter of this if the weight/part two of the bottom case is brass.
  • Cherry Peasant
  • keycult.com
« Reply #20 on: Wed, 14 June 2017, 19:46:39 »
The prototype uses chrome-plated brass. I don't think the chrome plating should be used any more other than this prototype because it led to a few issues with the prototype that wouldn't have occurred with a simpler finish.
« Reply #21 on: Wed, 14 June 2017, 19:55:55 »
ill dispose of this prototype for you
  • Cherry Peasant
  • keycult.com
« Reply #22 on: Wed, 14 June 2017, 19:57:36 »
It's a total POS and anyone who says otherwise is lying
« Reply #23 on: Wed, 14 June 2017, 20:32:22 »
if the prototype sucks then that means there's lots to learn on how to make the final product even better :thumb:
Offline pr0ximity
« Reply #24 on: Wed, 14 June 2017, 20:55:28 »
Hyyyyyyped, very excited to see people innovating the sandwich mount. Really impressive for a first design, will be cool to see what keysets people pair with different mid layer colors  :D
  • Cherry Peasant
  • keycult.com
« Reply #25 on: Wed, 14 June 2017, 21:31:15 »
Ye, it's actually quite nice but there are a few issues that will indeed be resolved :D
« Reply #26 on: Wed, 14 June 2017, 23:37:31 »
why u do dis when i spend all my monies on mira
looks very nice my dude
Offline Tally810
« Reply #27 on: Thu, 15 June 2017, 00:46:26 »
Nice design dude love the weight and the curves.  Looks sharp
Sent from my SM-G928V using Tapatalk
Offline merlin64
    • MechMerlin
« Reply #28 on: Thu, 15 June 2017, 16:22:47 »
Very nice! What CAD program did you end up choosing to make this, and did you design this from the ground up, or did you base it off of yuktsi's TKL?
Offline oatmicro
« Reply #29 on: Thu, 15 June 2017, 17:14:51 »
Wow, love the design  :thumb:
Offline sony
  • Formerly ultraidiot
« Reply #30 on: Thu, 15 June 2017, 17:15:37 »
Looks cool. The mounting is interesting. Any idea what colors you'll run it in?
  • Cherry Peasant
  • keycult.com
« Reply #31 on: Thu, 15 June 2017, 18:47:30 »
This was designed from the ground up with the exception of the plate switch cutouts, which was modified from yuktsi's TGR plate as I didn't have a good enough process yet to do it correctly on my first try. Multiple people provided useful feedback and help navigating the manufacturing process however.
I used Fusion360, which offers a free license for non-commercial use.
  • Cherry Peasant
  • keycult.com
« Reply #32 on: Thu, 15 June 2017, 18:48:38 »
A small run is already in the works. I'll post pictures when boards arrive. I hope a larger run will be available later on, but I'm not sure which colors would be available for that.
Offline Gajible
« Reply #33 on: Thu, 15 June 2017, 18:49:28 »
I would buy this without a second thought!
« Reply #34 on: Thu, 15 June 2017, 21:23:14 »
Oh, I forgot about the most important part:
Can we get some in-the-dark pics for the underglow? I wanna see what it looks like.
    • WTB/WTTF Thread
« Reply #35 on: Thu, 15 June 2017, 22:00:32 »
There is no underglow. That spacer is metal.
  • Cherry Peasant
  • keycult.com
« Reply #36 on: Thu, 15 June 2017, 22:22:48 »
Yeah. Honestly, I didn't even install LEDs in the prototype because it's not important to me. This keyboard won't light up your room, but it'll look good during the day. :D
« Reply #37 on: Thu, 15 June 2017, 22:45:40 »
Oh. I'm dumb. It looks great though.
A diffused spacer with a little underglow would look sweet, but maybe MIRA spoiled me.
Offline wanewang
« Reply #38 on: Fri, 16 June 2017, 10:21:12 »
this is good! didn't have a chance to join the small GB :(
waiting for next (No. 2?) to come!
  • Cherry Peasant
  • keycult.com
« Reply #39 on: Sat, 17 June 2017, 12:10:58 »
Aluminum plate built with Hirose MX switches
« Reply #40 on: Sat, 17 June 2017, 12:30:06 »
wait is that what the dark blue looks like irl?
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #41 on: Sat, 17 June 2017, 12:39:17 »
I think I've seen this somewhere before... :))
Sexy stuff, Riot.
  • Cherry Peasant
  • keycult.com
« Reply #42 on: Sat, 17 June 2017, 13:00:41 »
No, the dark blue is much darker. This plate is a prototype blue that won't be offered (and the case is a prototype blue gray that also wasn't offered).
« Reply #43 on: Sat, 17 June 2017, 13:52:13 »
oh phew unlucky
  • Cherry Peasant
  • keycult.com
« Reply #44 on: Wed, 21 June 2017, 15:27:48 »
Sorry for the delay. =)
Offline nickheller
  • Cherry ML life
    • hickneller.com
Re: New custom TKL "No. 1" (prototype & renders inside)
« Reply #45 on: Wed, 21 June 2017, 15:39:52 »
dang that's nice :cool:
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #46 on: Wed, 21 June 2017, 17:23:02 »
how about whole back side?
  • Cherry Peasant
  • keycult.com
« Reply #47 on: Wed, 21 June 2017, 17:31:30 »
Please, full frontal wasn't enough?  :rolleyes:
Offline joey
« Reply #48 on: Wed, 21 June 2017, 17:39:59 »
Amazing pics  :thumb:
Offline pr0ximity
« Reply #49 on: Wed, 21 June 2017, 18:04:15 »
