Author Topic: What features does your ideal custom keyboard have  (Read 5927 times)
« on: Wed, 14 June 2017, 23:46:22 »
Not form factor, just features.
Givens:
  • Fully programmable
  • Full LED compatibility
Mostly looking for things like "underglow" or "split spacebar"
Your feedback might end up on a custom board.
Thanks,
P
Offline laughatpain
Re: What features does your ideal custom keyboard have
« Reply #1 on: Wed, 14 June 2017, 23:53:58 »
Top and Bottom case lock in together so the sides are always flushed.
Through bottom weight.
Partial plate.
I guess these fall under form factor, when I see features I think exclusively about the PCB or plate
« Reply #2 on: Wed, 14 June 2017, 23:55:29 »
Partial plate.
i forgot about a thru weight
that's also implied
Offline f32h80fsd08h34r5
« Reply #3 on: Thu, 15 June 2017, 00:07:14 »
Topre Switches, HHKB Layout.
ACtually, just an hhkb.
Offline Fiery
  • Click Clack Clock and a nice Thock
« Reply #4 on: Thu, 15 June 2017, 00:50:40 »
  • Split spacebar
  • ISO layout
  • underglow backlight in a simplistic colour
I would also like to get a Norwegian PBT ISO layout in Dvorak keycaps, but that's hard to do (not SA or DSA Caps though)  :p
TP4 fanboy
Offline klennkellon
  • I like bottoming out
« Reply #5 on: Thu, 15 June 2017, 00:53:18 »
TKL
Cherry profile PBT
Alps switches
I'm set for life.
Offline loud_asian
« Reply #6 on: Thu, 15 June 2017, 03:51:37 »
USB-C would be nice. Future proofing your $500+ keyboard is a no brainer
Offline zylinderhut
« Reply #7 on: Thu, 15 June 2017, 03:53:26 »
  • small dial for LED intensity in an unconspicuous place (not a fan of a remote)
  • small dial for LED colour in an unconspicuous place
  • Underglow
Example of how a dial for intensity could look like:
Offline davkol
  •  Post Editing Timeout
« Reply #8 on: Thu, 15 June 2017, 03:58:26 »
software
  • customizable on any platform (i.e., open-source firmware flashable from anywhere), or the latest Kinesis' approach
  • unlimited keymap configuration, layers and dual-role keys
connection
  • detachable cable with a durable connector, e.g., SDL or RJ11, worst case properly implemented microUSB (because they're abundant)
  • NKRO
keys
  • quiet, deep thock sound, no higher-pitched clicking, clacking or pinging
  • shine-resistant surface, that doesn't get sticky/dirty easily
  • labels, that aren't tactile (e.g., dye sublimation)
  • no lights
  • contoured key tops (ideally slightly spherical)
  • damped impacts without too much mushiness; perhaps high actuation point and damping through post-actuation travel
  • smooth travel
  • subtle tactility (parabolic curve, duh)
case
  • lightweight but with good rubber stickers
  • scratch-resistant
  • no lights other than, perhaps, dim/reflective strips on the edges
  • minimal bezel
  • no "floating" design, i.e., with a lid to protect keys in the corners
layout
  • about as wide as tenkeyless, or narrower
  • symmetrical (columnar or symmetrically staggered)
  • non-trivial hand separation/angle
  • home positions close to keyboard edges to minimize reaching distance to an external pointing device
  • accessible modifiers and special keys: probably thumb keys in combination with the outermost columns
  • the same modifiers on each side, symmetrically placed (at least Ctrl, Alt, Shift, AltGraph, Super)
Offline pabile
    • pabile online
« Reply #9 on: Thu, 15 June 2017, 04:09:12 »
only thing missing from my 60% AEK is split spacebar.
2x3u or 2u+4u spacebars will make my custom board perfect  :thumb:
Offline zslane
« Reply #10 on: Thu, 15 June 2017, 12:22:06 »
  • Topre RealForce RGB guts
  • White (powder-coated) CNC aluminum case
« Reply #11 on: Thu, 15 June 2017, 12:30:46 »
Split space option, 60% or 65%, Alps compatibility.
I don't care about LEDs at all.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #12 on: Thu, 15 June 2017, 13:06:24 »
>=100% form factor
Focus layous
Alps SKCM blue
thin ABS doubleshot keycaps
thick, plastic case
steel chassis
Oh wait, I already have that :p .
Offline FoxWolf1
  • 154
« Reply #13 on: Thu, 15 June 2017, 13:25:56 »
True NKRO over USB, waterproof/dustproof/chatterproof, at least two integrated pointing devices (a TrackPoint in the usual place, and another pointing device of some kind near the arrow keys), 100%+, big-ass enter and 2u backspace (\ belongs on the same row as /; just reduce the size of right shift), copious internal stress relief for the USB cable, full-height case, 1000hz, no aluminum, no domes (not even ones with springs under them).
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
« Reply #14 on: Wed, 21 June 2017, 17:44:28 »
-ANSI with ISO enter and backslash
-A couple toggle switches that can be assigned to swap whatever we want
-Space for mounting through-hole LEDs on the bottom (for underglow)
-Split backspace (1xDel, 1xBkSp)
-Split left shift
-Split right shift
-Heavy duty PCB, for soldering noobs
-Both Alps and Cherry mount
-Decent price point
-Easy programming support for alternate-action switches (MX Lock, etc)
-Not smaller than 60%
-Plate has cutouts for switch top removal
That's about it.
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
Offline hkf
  • your #1 fan
« Reply #15 on: Wed, 21 June 2017, 17:48:21 »
Programmability
Split backspace
pretty lights
Offline killyou
« Reply #16 on: Thu, 22 June 2017, 08:50:09 »
1. Programmable
2. Hot swappable switches
3. Option to split RSHIFT and Backspace (60% form factor)
4. Gotta love that bank gothic Pok3r keycaps, I wish the legend would not fade.
That' all. I don't need much, I'm happy with Pok3r.
Offline zeltner
« Reply #17 on: Thu, 22 June 2017, 09:02:13 »
I've always wanted a keyboard for my living room with the following
-wireless
-built in pointing device (track point or track pad)
Basically something like a logitech k400 but mechanical.
Offline chyros
  • a.k.a. Thomas
« Reply #18 on: Thu, 22 June 2017, 10:02:57 »
True NKRO over USB
I don't think that's possible.
Offline algernon
  • A tiny mouse, a hacker.
    • Diaries of a Madman
« Reply #19 on: Thu, 22 June 2017, 10:22:10 »
The Keyboardio Model 01, where the palm keys are also trackballs. You could still press them, and they'd act as keys then, but they'd double as trackballs too. Also a slightly more powerful MCU than the Atmega32U4, so that I can fit more crazy stuff into the firmware.
Offline DKrause
« Reply #20 on: Thu, 22 June 2017, 12:52:23 »
1: Fully, completely programmable, including the option to program totally functionless dead keys.
2: Fully programmable per key RGB so a keys current function is clearly indicated. (Like the Anne Pro during Bluetooth programming)
3: Firmware that also allows "Double-Taps" as a modifier so a "Double-Tap Left shift" would set/reset Caps Lock. (The most worthless key on a keyboard, located in a premium spot.)
4: 60% form factor
5: Excellent double shot PBT caps.
6: Heavy, quiet case. (Like a Pok3r)
7: USB C. (It IS the 21st century after all...)
Not asking for too much really...
Offline killyou
« Reply #21 on: Thu, 22 June 2017, 13:24:19 »
+1
Opens possibilities to go crazy with cables for next to nothing instead of DIY or 20$ ones off massdrop ...
Online Findecanor
« Reply #22 on: Thu, 22 June 2017, 13:59:38 »
Have tinkering and mods in mind:
* If you don't include a pointing device, do at least offer the option to add one: Holes on the PCB/bottom for mounting one or several of the available trackpoint modules out there and three switches in front of the space bar for mouse buttons.
* If you don't split the space bar, allow the option for it.
* Support ISO and ANSI. (That should be a given.)
* Header for additional keys or functions.
I don't agree with having USB Type C. Cables are thicker than other USB cables, pointless unless you can use the additional capacity and there are reversible Micro B plugs around.
True NKRO over USB
HaaTa's Kiibohd firmware has it, and maybe others. The difficulty has been to cater to various operating systems' different quirks. I think those have been found now and adjusted for.
« Last Edit: Thu, 22 June 2017, 15:05:08 by Findecanor »
Offline ErgoMacros
« Reply #23 on: Thu, 22 June 2017, 14:38:54 »
Yes to:
* Fully programmable
* Open source: I want full control
* Ability for the OS/Apps to tell the keyboard what I want. (Changing apps can change layout)
* At least a Atmega32U4
* OS X, at least
* detachable cable
* Either about 60% split or 145% layout. I'm an extremist. So looking forward to the GH-122 at about 146 keys.
* LED intensity control for backlight only.
* At least 7 single LEDs that I can control in software. Things like NumLock, status of mod keys (held, locked, in 1-shot mode),  Active layer.
* Low profile
Don't want:
* RGB LEDs
* Per key LED
Today's quote: '...“but then the customer successfully broke that.”
Offline davkol
« Reply #24 on: Thu, 22 June 2017, 14:40:44 »
Support ISO and ANSI. That should be a given.
And JIS, ahem.
