Author Topic: Parking and building location info  (Read 112103 times)
Offline att1cus
« on: Mon, 19 June 2017, 08:12:36 »
Hey everyone!  The con is less then a week away, so I thought I'd post this!
Timing
We're going to start setting up in the rooms around 10AM, and will hopefully be fully set up by 11AM.  Attendees are welcome in the rooms anytime from about 11AM till 8PM.  If anyone would like to arrive early to help set up, that would be welcome :)
Parking
All parking will be free of charge
Most of you will be entering the Villanova area from the blue route (476), which will drop you onto Lancaster Ave.  You'll see most of the university's buildings and main lawn on the left-hand side of the road as you proceed along Lancaster.  When you hit Ithan Avenue, make a right, and park in the only large parking garage on the left. It will be labeled I-1 or Ithan Garage
For more information on where to park, please take a look at the Villanova parking garage map:
https://www1.villanova.edu/content/dam/villanova/publicsafety/documents/MapofCampusParking%20Changes(2016-2017).pdf
All cars in attendance have to have the guest parking permit for Keycon 2017 on their dash boards.  Please print one out and leave it visible when you park.
https://www.dropbox.com/s/u3epfl67b6gohg2/Guest%20Pass.pdf?dl=0
Building
We will be using rooms 2001 and 2010 in Bartley Hall on Villanova's campus.
Here's the Google Maps pinpoint for the building:
https://goo.gl/maps/2y2YgVZR9DF2
The building is right at the intersection of Ithan Ave. and Lancaster Ave. and has large signs at all entrances with the name displayed (Bartley Hall or Bartley School of Business).  For those who park at the Ithan garage, you will exit the garage after parking and proceed along Ithan ave towards Lancaster ave. (away from the small bridge over Ithan ave.) and cross over Lancaster Ave. to Bartley Hall.  Once inside, there are stairs and elevators available to take you to the second floor, where we will have the 2 large auditorium rooms at the far end of the building: Rooms 2001 and 2010.
I will try to post some signs around the building to help direct to the proper rooms.
Feel free to ask any questions.
« Last Edit: Tue, 20 June 2017, 07:24:41 by att1cus »
Offline cynviloq
Re: Parking and building location info
« Reply #1 on: Mon, 19 June 2017, 10:09:12 »
Quickly made this to keep as a guide for myself, but sharing it for anyone else that wants it. Just some of the info from above on the map.
« Last Edit: Mon, 19 June 2017, 17:41:53 by cynviloq »
Offline att1cus
« Reply #2 on: Mon, 19 June 2017, 10:13:01 »
http://i.imgur.com/5kui9gb.png?1
Unfortunately that link isn't working for me ATM.
Offline Hookerlips
« Reply #3 on: Mon, 19 June 2017, 15:55:06 »
What time is everything going down, and is there a registration?
Offline cynviloq
« Reply #4 on: Mon, 19 June 2017, 17:32:19 »
Sorry - how about now?
Offline att1cus
« Reply #5 on: Mon, 19 June 2017, 17:35:29 »
Works now thanks!!
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #6 on: Mon, 19 June 2017, 17:49:11 »
Awesome, thanks!
Do you need help setting up/taking down? What time should we plan to be there?
-Dana
Offline I_need_a_bath
« Reply #7 on: Mon, 19 June 2017, 19:21:08 »
What time is this taking place at?
Offline Hookerlips
« Reply #8 on: Mon, 19 June 2017, 22:31:01 »
Awesome, thanks!
Glad I'm not the only one who can't figure it out!
Offline fendent
« Reply #9 on: Tue, 20 June 2017, 06:33:35 »
Awesome, thanks!
Doors open at 11am! We will start setting up around 10am. :)
Offline att1cus
« Reply #10 on: Tue, 20 June 2017, 07:27:58 »
Awesome, thanks!
Awesome, thanks!
Awesome, thanks!
Added the timing information to the main post - sorry about that!
Offline digisax
« Reply #11 on: Tue, 20 June 2017, 09:09:55 »
Awesome, thanks!
If I'm up in time (and there's a decent chance I won't be) I'd be willing to help set up.
niu mini - R2 T1s, MT3 Dev/TTY
Offline KACHAKEYS
« Reply #12 on: Wed, 21 June 2017, 12:32:59 »
IF I am planning on selling artisans, should I arrive earlier or later than 11. Also Is there any registration, the other threads heave me a bit confused.
Offline att1cus
« Reply #13 on: Wed, 21 June 2017, 18:39:15 »
If you'd like extra time for setting up a space for selling caps, you may feel free to some anytime after 10am.  There is no registration, just print and display the parking pass if you're parking at the con.
Offline KACHAKEYS
« Reply #14 on: Wed, 21 June 2017, 18:53:43 »
Awesome, ill be sure to print the pass. I may be a little later than noon depending on the traffic/if I can afford zipcar for the whole day.
Offline Dernubenfrieken
« Reply #15 on: Sat, 24 June 2017, 10:39:55 »
FYI, enter on Lancaster, the ithan entrance is closed
