Author Topic: Tx87 leeku pcb, Capslock LED  (Read 2509 times)
Offline Yuuki
« on: Tue, 20 June 2017, 04:02:54 »
Hello,
I always invert capslock and control on my keyboards.
I did it for the tx87 pcb, using Jigon software.
But if i press on the new capslock, it's the LED of the ancient capslock that lights up (where the new control is).
Is it possible to reprogram which LED light up according to your new capslock position ?
For reference, if you do this with a RF 87 dip switch, the LED will be inverted too
Best regards
Offline punksinatra
    • Random Stuff
Re: Tx87 leeku pcb, Capslock LED
« Reply #1 on: Thu, 21 September 2017, 00:08:04 »
did you ever find the answer for this?
