Author Topic: Keyhugger - Kachakeys  (Read 5743 times)
Offline KACHAKEYS
« on: Wed, 21 June 2017, 19:02:00 »
Hi all
were proud to show off our first keycap, the Keyhugger in much nicer pictures.
So far only MX stems have been produced, topre might happen in round 2.
Two of these little guys are going to be donated as prizes for keycon 2017!
Let us know what you think!
Also soon well post about our caps designed to match >_terminal GMK.
Thanks- Kachakeys
Offline ArchDill
Re: Keyhugger - Kachakeys
« Reply #1 on: Wed, 21 June 2017, 19:34:17 »
I can not tell what it is exactly..
Offline KACHAKEYS
« Reply #2 on: Wed, 21 June 2017, 19:36:52 »
Offline omgkittiesyay
« Reply #3 on: Wed, 21 June 2017, 19:38:19 »
its creepy-cute is what it is
Offline KACHAKEYS
« Reply #4 on: Wed, 21 June 2017, 19:44:12 »
Its You...
« Reply #5 on: Wed, 21 June 2017, 19:45:40 »
WHAT IN TARNATION?
« Reply #6 on: Wed, 21 June 2017, 19:51:45 »
« Last Edit: Wed, 21 June 2017, 19:56:16 by omgkittiesyay »
Offline ArtKey
  • https://www.instagram.com/artkey.universe/
    • ArtKey - Your MechKey Companion
« Reply #7 on: Sun, 25 June 2017, 07:28:32 »
What is it,honestly? I tried to define it several times
« Reply #8 on: Sun, 25 June 2017, 11:37:23 »
its based on a creature called the "facehugger" from the scifi horror series Aliens.  http://bit.ly/2rQt6Vg
Offline Nonster
  • Lo-Ki Studios
« Reply #9 on: Sun, 25 June 2017, 16:41:37 »
I'd like to see one on G20 Semiotic.
Offline SeedyOne
« Reply #10 on: Fri, 21 July 2017, 19:53:33 »
Creepy! H.R. Giger would be proud.
Offline KACHAKEYS
« Reply #11 on: Sat, 22 July 2017, 00:48:12 »
Thank you!  I dont think its phallic enough for that though!
