Author Topic: Obscure switch (if it IS a switch...)  (Read 2903 times)
Offline ander
  • I type, therefore I am
« on: Fri, 23 June 2017, 23:47:17 »
Anyone seen a switch like this?:
171459-0
It's in a "Legend" keyboard someone in Latvia is selling here on eBay. They've described it as a "Vintage Mechanical Clicky Keyboard", but you know how that can be—it may just feel and/or sound "clicky" to them.
Anyway, I've never seen anything like it—have you?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Obscure switch (if it IS a switch...)
« Reply #1 on: Sat, 24 June 2017, 02:47:30 »
Must be some kind of dome with slider mechanism.
Offline slot demon
« Reply #2 on: Sat, 24 June 2017, 06:07:09 »
The keycaps could be alps compatible.
« Reply #3 on: Sat, 24 June 2017, 06:28:54 »
It can't likely be anything but a rubber dome with slider, considering how little space there is left inside that housing.
It is also probably (but not always) domes when the housings are integrated with the bottom.
There are many rubber dome with Alps-slider designs. Many times where the keycaps are compatible with Alps switches, the stabilisers are not compatible with either Alps or Costar-stabilisers.
Offline ander
« Reply #4 on: Thu, 29 June 2017, 14:52:43 »
That's the feeling I got, too. As you know, though—back before anyone could order whatever they wanted from Taiwan—the Eastern Bloc saw a fair amount of "let's reinvent the wheel, Comrade" IT development, so one could never be sure.
The seller also refers to the board as "mechanical", though we all know from experience that's no guarantee.
Looks that way, doesn't it?
It is also probably (but not always) domes when the housings are integrated with the bottom... There are many rubber dome with Alps-slider designs. Many times where the keycaps are compatible with Alps switches, the stabilisers are not compatible with either Alps or Costar-stabilisers.
Dang—and it was such an appealing idea, transferring a button set from an Alps boards to this RD one.  :?)
Offline mushmouth
    • mushmouth (Patrick Lonergan) Personal Site
« Reply #5 on: Thu, 29 June 2017, 19:48:33 »
How does it feel to type on if anybody has used it?
