Author Topic: [IC] DSA Pot o' Gold  (Read 3851 times)
Offline AuthenticDanger
« on: Tue, 27 June 2017, 23:16:59 »
I've been messing around with an idea of doing a Leprechaun/Luck inspired Green/White/Gold set.
The novelties are just some ideas I had to spruce up the design and would need to be redone/redrawn (I pulled them straight off a Google Image search).
The set will be doubleshot ABS in DSA profile.
Possible additions:
  • Celtic legends and/or novelties
  • inverted alphas/mods
SP Color codes:
VCM - Green
WFK - White
YCH - Yellow
Looking forward to any and all feedback.
Thanks for looking!
« Last Edit: Wed, 28 June 2017, 09:29:13 by AuthenticDanger »
F Keys belong on the left.
Re: [IC] DSA Pot o' Gold
« Reply #1 on: Tue, 27 June 2017, 23:20:39 »
DSA Senna?
Offline lovetree
« Reply #2 on: Wed, 28 June 2017, 00:04:57 »
This is just my prederence. If legends are little bit bigger, it might be look botter.
« Reply #3 on: Wed, 28 June 2017, 09:29:51 »
Yeah, that's just the default size in KLE. I made the alpha font size bigger for the render now.
Offline Bob
  • Kaleidographer
« Reply #4 on: Sun, 02 July 2017, 23:19:48 »
YCH looks more yellow than gold. Maybe switch to a warmer/browner yellow such as YL or YW?
For the novelties, a four leaf clover has to be in there, right? ;D
TG3 BL82, Cherry MX clears
Access IS 15x8 matrix layout, Cherry MX blacks
