Author Topic: Hi everyone!  (Read 2558 times)
Offline iskalamberge
Hi everyone!
« on: Thu, 29 June 2017, 09:59:39 »
Been lurking for a while now.
Started with mechanical keyboards November last year when my G110 retired and was becoming really hard to type on even after dismantling everything and washing the membranes and cleaning everything else.
Anyhow, a friend introduced me to a local GB in the Philippines where I first got a tada68 with gat browns.
I enjoyed it a little bit but the sound it makes didn't feel right.
tried the k65 cherry reds and didn't feel right, got the cherry blues master keys pro L but was gritty AF.
went for an anne pro with gat browns felt really good but still bad sounding, someone from our local group mentioned because it was hollow.
I got some b96 but the plates were skewed it was also in gat browns so i desoldered everything and is still in the verge of trying to get the plates straightened out or probably try to find a case that would fit it in nicely.
Then I went for a KBD75 still waiting on the R4 GB in gat browns as well.
So I went to SG to pick up the delta split75 by xyxjj. dunno if he's here but in kailh speed bronze.
Which I am currently using now and is very happy with it.
oh and I got a MagicForce82 somewhere in between but sold it the next day.
Please ignore the cables, just got an off the shelf one for the meantime
rooting to get a Kira someday. and an Ashen too
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Re: Hi everyone!
« Reply #1 on: Sat, 01 July 2017, 12:57:55 »
Dang, the Delta Split 75 has changed quite a bit. Mmmm, yummy F row.
Made a split 65% keyboard - by xyxjj
Welcome to GH :)
Offline OneNightFriend
Re: Hi everyone!
« Reply #2 on: Sat, 01 July 2017, 13:37:02 »
Welcome and nice keyboard! Is it USB-C  connecting the two pieces?
Re: Hi everyone!
« Reply #3 on: Sat, 01 July 2017, 14:09:25 »
Welcome to GH :)
Thank you!
Oh wow! so it was a 65% originally. I only found out about it through discord when he posted about the GB. Looks sweet either way.
Thank you! It uses a trrs to connect both boards. I am using an off the shelf trrs cable for the meantime while waiting for one to be made.
