Author Topic: Noppoo Choc Mini on Aliexpress (difference?)  (Read 2138 times)
Offline dragonload
« on: Thu, 29 June 2017, 12:57:53 »
Hi, if you search for Noppoo Choc Mini on Aliexpress.com you find 3 different keyboard-seller. I wonder if there is a difference between those 3 Mini's.
I ordered one from seller "Shenzhen YMD Tech Co.,LTD Store" because of quicker delivery. But now i realized the link says "Gateron" even if the product description says its with Cherry Switches.
And whats with the product version? Are they all the same?
Offline xuanwumen
  • * Commercial Vendor
    • EZKB
Re: Noppoo Choc Mini on Aliexpress (difference?)
« Reply #1 on: Mon, 03 July 2017, 09:39:32 »
Most of Noppoo mini 84 are with cherry switch. Only some are with gateron switches. Better to check before buy.
NIZ KEYBOARDS VENDOR
