Author Topic: standalone numpad advice?  (Read 5232 times)
Offline Prisoner416
« on: Mon, 10 July 2017, 00:29:41 »
I have a CMStorm Quickfire rapid, and love it, but the one thing I forgot when buying it about a year ago was the number of game trainers I had that required num pad input.
I'm looking for a standalone numpad that would fit the appearance of my keyboard and feel right next to it, about the same distance from the desk.
I don't need anything fancy like expensive switches, I just need to know that the device will work. Since my keyboard doesn't have a usb extension, it would need to have an average length usb cord.
Failing that... I could just buy a CM Storm QuickFire XT, but if I'm going to buy a whole new keyboard, I'd rather upgrade a bit and have something like a bit of backlighting. (I know it's a gimmick, but I do play in low light sometimes.)
I was looking at the Cooler Master MasterKeys Pro L briefly, but I wish they still had the custom keycaps like the Quickfire had.
So... any advice?
Offline Tactile
Re: standalone numpad advice?
« Reply #1 on: Mon, 10 July 2017, 01:59:41 »
The neat thing about external numpads is they aren't glued to the end of the keyboard and can be moved. When I'm using one I tend to put it way off to the right. If you don't anticipate moving it to an unconventional position you might as well just get a full sized keyboard. Only one cable to deal with and just a nice package overall. The only problem is choosing one - there are quite a few good ones out there.
I'll put my vote in for the Ducky One. A very nice feature set for the price.
REΛLFORCE
Offline SBJ
  • Tactile pls
« Reply #2 on: Mon, 10 July 2017, 03:26:15 »
I've been eyeing the VA22M myself from Varmilo.
You can get it customized from Varmilo, it would run you probably around $50 for the device + fees & shipping though.
Offline clee290
« Reply #3 on: Mon, 10 July 2017, 09:24:00 »
I've always been interested in getting a Roadkit from thevankeyboards.com to use as a number pad. It's a bit on the expensive side though, but they did recently release a version with a 3D-printed that is more wallet-friendly. And it's fully programmable, so you can have layers for others things like macros, media keys, etc.
Offline TalkingTree
    • My projects
« Reply #4 on: Mon, 10 July 2017, 09:36:09 »
On the cheap side there's there Jelly Comb mechanical numpad on Amazon.
« Reply #5 on: Mon, 10 July 2017, 09:43:58 »
I'm using the Jelly Comb, I have a hard time justifying spending more than that for the handful of times it gets used in a day. The Oetumu switches feel fine and the build quality is very good, not just for how cheap it is.
Offline ander
  • I type, therefore I am
« Reply #6 on: Wed, 09 August 2017, 18:07:16 »
I've always wondered: Isn't "QuickFire Rapid" redundant? Or do they also make something like a "QuickFire Average Speed" that they had to distinguish it from?
Offline Rad
« Reply #7 on: Wed, 09 August 2017, 21:41:11 »
I have the Leopold FC210TP with black switches. It's a nice little numpad, but sometimes the keys don't register.
Offline Zobeid Zuma
« Reply #8 on: Thu, 10 August 2017, 03:43:58 »
I, uh. . .  I have to confess, I picked up one of the semi-disposable black $8 num pads from Wal-Mart.    :-[
It works Just Fine, with the understanding that I don't do much numeric entry and could get by OK without any num pad at all.
However. . .  Just do a search for "numeric keypad" on Amazon!  There's a dizzying array of num pads on the market.  In particular, I notice the Beeiee comes with Outemu blue switches, and the price is very good.  I have a full keyboard with Outemu blues, and I like them a lot, especially since I put O-rings on them to tame the plastic clack.
Offline Marvellion
II
« Reply #9 on: Thu, 10 August 2017, 12:47:21 »
Cospad could be a nice choice, its on Aliexpress. But its a DIY kit and I tjibk you will need your own USB cable.
Offline quasistellar
« Reply #10 on: Thu, 10 August 2017, 15:00:20 »
Or you could get a CM Masterkeys M or a FC980M.
