Author Topic: Best replacement foam for keytronic foam and foil switches  (Read 3935 times)
Offline PancakeMSTR
« on: Mon, 10 July 2017, 22:45:23 »
Hi,
I've got a keyboard which uses keytronic foam and foil switches and the foam (and foil, but I've got that figured out) has completely deteriorated, on every switch.
I can replace the foam pads, but I'm not quite sure what the best foam to use would be. Could anyone offer me advice? An amazon or link to some other place where I could buy the foam would be fantastic, too.
Thanks.
Offline OldIsNew
Re: Best replacement foam for keytronic foam and foil switches
« Reply #1 on: Mon, 11 September 2017, 08:32:23 »
I'm not sure this qualifies as "the best" - but it did work. I went for local sourcing and bought what was available at Walmart and Michael's:
178087-0
Used a 7/16" leather punch and sliced the foam into 0.20" segments
178089-1     178097-2
Saved and cleaned the original plastic disks for the plastic/foam/foil sandwiches then glued on the foam and foil (non-conductive side of foil facing PCB):
178091-3     178093-4    178101-5
Took a while but it's working well.
« Last Edit: Mon, 11 September 2017, 08:40:32 by OldIsNew »
