Author Topic: Monoprice D20 RGB Backlit MX Brown -- $59.50  (Read 4790 times)
Offline xmagusx
  • QWERTY is hateful.
    • The Ergonomic Zone
« on: Sun, 16 July 2017, 21:02:54 »
MP D20 RGB Backlit Mechanical Gaming Keyboard, Cherry MX Brown Switches
https://www.monoprice.com/product?c_id=114&cp_id=11401&cs_id=1140102&p_id=12515
Enjoy the reliability, durability, and pleasant feel of genuine Cherry MX mechanical keyswitches combined with the beauty of 16.7 million colors from the full-spectrum RGB LED backlighting. The uncompromised quality continues with a heavy-duty wrist rest and double-injected keycaps, which ensures that the letters and numbers will never rub off or fade over time. Featuring an anti-ghosting design that allows for up to 64-key rollover, this USB keyboard includes a 2-port USB pass-through hub and 3.5mm microphone and speaker jacks.
Whether you are a gamer or an office user or both, you will enjoy the flexibility and convenience of multiple profiles and on-board memory for storing customized settings and macros. This means that you can move the keyboard from computer to computer without the need to reconfigure it or even to install the included customization software.
Offline Techno Trousers
  • ʘ_ಠ
Re: Monoprice D20 RGB Backlit MX Brown -- $59.50
« Reply #1 on: Sun, 16 July 2017, 23:32:44 »
Damn nonstandard bottom row
Offline ander
  • I type, therefore I am
« Reply #2 on: Thu, 20 July 2017, 05:29:02 »
They go on about how durable the wrist rest is, but don't say a thing about the case or the build in general... Does that seem a bit odd?
