Author Topic: Where to get rubber keyboard wrist rest?  (Read 6618 times)
Offline typo
« on: Thu, 20 July 2017, 09:20:16 »
Many B&M's used to sell rubber core keyboard wrist rests with a Lycra covering. Like OfficeMax, Staples,Walmart ETC. I find none anywhere I have looked now. These are similar to Griffiti but not exactly the same. For one thing they are covered on the sides which I prefer. They were anywhere from $5-!5 in the early 2000's. I know where to get them online. I was wondering if anyone knows a national B&M that carries these anymore?
Thanks
Offline Auk
Re: Where to get rubber keyboard wrist rest?
« Reply #1 on: Thu, 20 July 2017, 09:31:18 »
Staples don't have them?
Do you have any independent stationers in your town/city?
« Last Edit: Thu, 20 July 2017, 09:35:47 by Auk »
Offline typo
« Reply #2 on: Thu, 20 July 2017, 09:57:00 »
Staples no longer has them. I do not know what kind of store you mean? I am by Chicago.
Offline Auk
« Reply #3 on: Thu, 20 July 2017, 10:05:41 »
Stationer - a store that sells stationary and office supplies.
I just did a quick search on "stationer chicago" : Startpage or DuckDuckGo
Check out the results in Yellowpages, Yelp etc. and you may be able to find something.
Offline typo
« Reply #4 on: Thu, 20 July 2017, 10:17:27 »
Thank you
Offline typo
« Reply #5 on: Fri, 21 July 2017, 03:55:02 »
Could not find it anywhere locally. Ordered online. IMO these are the best rests. Much harder than gel/foam and not as hard as wood. I do not like Griffiti since it is not covered on the sides. Went with Innovera which is what I currently have and is worn out.
