Author Topic: Extending the ergodox tent kit..  (Read 6579 times)
Offline darrenph1
« on: Thu, 20 July 2017, 13:51:40 »
The ergodox EZ tent kit doesn't tilt the keyboard high enough for my liking. Is there a way to extend the tilt kit? I was hoping to extend the legs and keep it cleaner looking that the foam I have currently under my razer orbweaver set up at a 45 degree angle. Also wondering about how some of you have tilted the wrist rests.
« Last Edit: Thu, 20 July 2017, 15:13:45 by darrenph1 »
Offline ddot
  • Master of Suspense
Re: Extending the ergodox tent kit..
« Reply #1 on: Thu, 20 July 2017, 14:44:24 »
There's so many different varieties of the ErgoDox out there now, you'll have to give us a better idea of exactly what case and tent kit you're using.
I tented my original Massdrop ErgoDox using some M3 spacers I picked up off eBay.  Something along the lines of this:
http://www.ebay.com/itm/M3x20mm-6mm-Male-to-Female-Brass-Spacer-Hexagonal-PCB-Standoff-Pillar-20pcs-/351957893918
Then just pick your length to adjust to the angle you want.  But depending on your case design, that may not work for you.
Offline darrenph1
« Reply #2 on: Thu, 20 July 2017, 15:14:32 »
Sorry, the Ergodox EZ.
